savethemanual
Earth
Future R2
The R1T doesn't have a rear wiper and it copes with winter just fine since day one. Defrost button does the work.
Yeah, big difference....there's a significant space (bed) between rear window and the road, not an apples to apples comparison at all. When the rear glass is actually the rear of the car, it has the potential to get dirty to the point of not being able to see out of it when driving in crappy weather. (Mid-West winters with salty roads & slush)
CharonPDX
Charon
Cascadia
InfoSec Geek
Serious question: why do you/we need a rear wiper? There isn't a rear wiper on sedans. The heating elements defrost the glass for you.
I don't on any of my current vehicles. But R2 is not shaped like a sedan. Rear up-spray collects on the rear windows of SUV-shaped vehicles. Having the more upright glass closer to the rear end is what makes a rear wiper preferred. The more teardrop shape of a sedan, combined with its rear window being further from the rear end of the vehicle, means airflow alone clears the back glass.
RivianTrackr
Jose
Winter Garden, FL
RivianTrackr.com
2025 Rivian R1T Tri Max, 2025 Rivian R1S Dual Large Performance
I wish I could say I was shocked at people creating a problem with the rear wiper but here we are, everyone's a wiper expert now.
mclark2112
Matthew
NJ
Finance
I can see mine getting filled with pollen and other tree gunk in the spring, but other than that I'm not worried.
Can we just close this thread lol? It's pointless. The OP just posted for clicks and has yet to even comment on this thread afterwards.
Hang around long enough and you'll notice that's pretty much all a handful of members do.
The rear up-spray is mostly the product of aerodynamics and the turbulent vacuum, or low pressure area, directly behind a boxy shape. This may not be as big of a deal with the R2 because they actually did wind tunnel and CFD work to improve aerodynamics and reduce drag. The rear of the R2 might still get dirty, but it likely won't be as bad as other 2-box designs that were never built with aero considerations. Cd figures for most cars can be looked up via web search. The R2 is said to be close to 0.3 (per Jeff Hammoud). And that is damn good for a 2-box. Previous generation Prius is said to be about 0.27 (same as the R35 GT-R). And unlike other cars, the R2's rear glass is recessed, not flush-mount. I suspect the R2's rear wiper won't be used as much and all this speculation and arguing is just fodder. When I lived in the Willamette Valley, I owned cars and SUVs with rear wipers—including a AWD DSM that was built in the same Normal IL plant—long before cars had cameras and long before OEMs paid much attention to aero and efficiency. The only times I used their rear wipers was when backing up in heavy rain. Or the rear window had leaves stuck on them. Or when my OCD compelled me to wipe the rear glass.
As for a prior comment regarding heating elements... I don't think I've seen a single complaint about the R1's ability to heat and defrost/defog the rear glass. It's just passing electricity through the embedded wire, and using the wire's resistance to produce heat. It's simple tech that became standard/common in the 1970s. Absolutely no reason to suspect it won't work in the R2.
The influencer's cheap attempt to get clicks... It's absurd. Regardless of where or how they are mounted, every single rear wiper has potential to be stuck and frozen whenever the necessary ingredients and conditions exist: moisture and freezing temps. Grade school level science?
Engineering, Dog Petting
100% FUD. Rivian developed their own motor for this that's significantly stronger than a normal wiper would need.
See the patent for more information, which it gives a ton of.
Mos Eisley
Minnesota
Mazda CX-5, CX-30 & R2 on the way!
Marketing & Sales Consultant, Freelance Photographer
The gap between the rear roof top rear spoiler and the roof line where the rear hatch hinges, creates downward flow that help keep the rear window cleaner than R1S.
Ask the Ioniq5 how that worked out.
I'm just here to say that influencers are the result of a realtor and a used car salesman having a baby. Let that sink in.
Just when I thought there was nothing lower than a used car salesman! Setting new low now..... 😟
Dasoss
Utah
RIVIAN R1S Quad Max Launch
Retired engineer
Video of Rivian R2 wiper in action (posted by Riviantracker) and reaction with potential issues brought up... legitimate concerns or FUD?
The R1S wiper is similar. The R2 wiper has to work with a completely disappearing drop window. They both work for rain, dirt, and mud that builds up on SUV and Hatchback rear windows. Yes, the wiper only clears a small part of the window. Is the rear window wiper even necessary? Most of the vehicles that i have driven didnt have rear wipers. Some didn't have usable rear windows. What about using the wing mirrors, the cameras, and the proximity sensors.
