Rivian API
AdamUCF
Orlando, FL
June 2022 R1T
I threw together a script (PowerShell since I'm a Windows guy but should work on Linux/Mac if you're into that sorta thing) that checks your order and guide status every 5 minutes and will let you know if it changes. Yes, very excessive but apparently I have nothing better to do with my time. I'll give a nod to @p3ck over here for the idea (and I put it on GitHub @AllInev).
Save/download this as Check-RivianOrder.ps1. Edit to fill in your user/password at the top. If you want immediate notification to your phone you can use a twilio account (they have a free trial) to get notified. Run it and it will check status every 5 minutes. It should be light enough so that even if a ton of people were to run it, it won't even be a blip on Rivian's radar. I'd be curious for someone who has a guide to run it and validate that it just returns to double check my work (though I'm pretty sure this will function how I assume).
p3ck
Bill
Massachusettes, USA
Hmmm.. This isn't working for me.
Code:
$ pwsh Check-RivianOrder.ps1
Check #1. 05/08/2022 12:35:24
orders is empty :(
Invoke-RestMethod: /home/bpeck/Check-RivianOrder.ps1:55
Line |
  55 |  … guideResp = Invoke-RestMethod "https://rivian.com/api/gql/business" - …
     | {"errors":[{"message":"User not
     | authenticated","extensions":{"code":"UNAUTHENTICATED"}}]}
no guide :(
I also had to comment out the [console]::beep(1000,500) since they are not available on the linux platform.
Could it be an issue with the mobile client id and secret?
pc500
dodge ram
Yeah it's a standard REST end points, so should not be that complicated. Unfortunately I do not have a vehicle yet but I did ask Rivian about API availability and they have ignored those emails, I even asked them on linkedin lol
I really want to be able to dig into the vehicle/API for accessibility reasons
You really don't need a vehicle for a lot of it. Get the app setup, disable certificate pinning, and poke around. You can at least get logged in and play a bit.
Some stuff will obviously only be possible with a vehicle, but you can do what the app can do.
AdamUCF
Orlando, FL
June 2022 R1T
Code:
orders is empty :(
Line |
no guide :(
I updated the script and it should work now. I probably should've tested before saying it would work. It wasn't an inherent flaw in the auth but a dumb PowerShell idiosyncrasy causing the issue.
AdamUCF
Orlando, FL
June 2022 R1T
Disabling the cert pinning was tricky. Not something I've done a whole bunch and maybe there's an easier way but had to patch the Android apk.
pc500
dodge ram
No easy way. Alternative is a rooted phone with modified SSL libraries.
Hopefully they just release a "unlocked" APK like Facebook does to just remove all the hassle... Let me know when you have it documented :)
p3ck
Bill
Massachusettes, USA
Did you update the gist? I pulled it again and it doesn't look changed. :)
p3ck
Bill
Massachusettes, USA
Nevermind.. I see it now. :) Not sure how I missed it.
Mysta
SC
Random note - does work show when guide is assigned correctly.
boardthatpowder
Dean
Rivian R1T, Audi Q5
Thanks to @AdamUCF for the reverse engineering to create the PowerShell script. I've ported it over to Python to be compatible with more architectures including Mac and Linux.
kanundrum
Washington, DC
pc500
dodge ram
Nice. That's much better than reverse engineering the thing from the APK
kanundrum
Washington, DC
Its actually all within the APK it self as well + a LOT more services such cloud uploader etc.
pc500
dodge ram
I actually didn't assume it would be there in the clear like that. I was just man in the Middling the app API calls.
Life's good.
GoWest!
Pacific NW
Subaru Outback & R1S
I can’t be the only non-tech person thinking this: “what?” This seems important but I have no clue what you all are talking about.
Non-tech language please…and thank you. ?
