Tim-in-CA
So Cal
Gen 1 R1S, Lucid Air, T-Bird
I’m not seeing charge graph while CCS charging. Plus they need to all customization to allow removal of aero inserts in 21” rims.
Edit : Found it. You need to swipe down to find charging status and tap to show graph. Why did they make this less obvious when there is so much wasted space in the app???
Revelation
North Carolina
Rivian Blue R1T
IT Solutions Architect
In all-fairness, the first time you launch the app post update you get notified of how to access charging info by swiping down.
Nametaken
Illinois, Beecher
Bronco, R1T, Vanderhall, Frontier
Is anyone else having an issue where the new app is using massive amounts of data? Since in installed it's been using about 800MB of mobile data per hour, non stop.
On android, it was running my battery down pretty quickly, switched itself to no restriction on battery use by itself.
CobraJerky
Cobra
Edmonds, WA
Commercial HVAC Service
This data usage is a serious issue! I can't tell you when this specifically started though I assume after the update. My phone has been hot today and battery at 28% which is extreme for my case.
*UPDATED - Added another screenshot* App has used 32% of the battery, today. I'm guessing 5gb of data as well.
Rivian R1T R1S Rivian app 2.0 is live! Screenshot_20230726_144616_Settings
Rivian R1T R1S Rivian app 2.0 is live! Screenshot_20230726_145552_Settings
Fozzy
Philadelphia
Yes whatever it's doing is using quite a bit of the phone battery. I have changed the app settings on Android from unrestricted and I'll see if that fixes anything.
Rivian R1T R1S Rivian app 2.0 is live! IMG_20230726_180032
Rivuylkill
Having the same issue.
trez63
R1T, Gladiator, Porsche GT4, and a bunch of bikes
crap. should have read this post before upgrading. How can I check how much data the app is using on ios?
trez63
I could be wrong, but I think one major difference is now you can access the charging schedule and limit menu and make edits even when the car is not plugged in. I believe that was only possible before if the car was being charged.
invernite
NW Chicago
2015 Honday Odyssey
Clicking refresh in the R1 Shop
Yeah, this new version is definitely an issue. Draining phone battery and blowing up data usage. Think I'm going to have to put on restrictions until they release an update.
Rivian R1T R1S Rivian app 2.0 is live! Screenshot_20230726-184955~2
invernite
NW Chicago
2015 Honday Odyssey
I believe you could do it before, even when not plugged in.
Under settings scroll down to battery and it will show you usage.
Mine seems to be ok. Phone has been unplugged for 12 hours, only down 18% and 20% of that is the Rivian app but I have been playing with it a lot today checking the app and the R1S.
invernite
NW Chicago
2015 Honday Odyssey
trez63
That’s battery, not data usage. Trying to see if anything on iOS indicates how much data an app is using.
