Stereo Volume is messed up
SPITmadFIRE
2024 R1S PDM Max Pack 20" AT
Totally agree with you. But I will try some of the suggestions listed here. One, too soft too too much in your face. Needs a 1.5.
I know you're joking, but it just needs to not be loud until at least 10 out of 30 ? so many people complained about 30 being too quiet before, now rivian came back and gave us hearing damage at 6. I don't even want to see what the rest of the range sounds like.
R1Thor
Joe
Lancaster, PA
Mechanical Engineering Lead
IF anyone is having this issue SPECIFICALLY while streaming audio via Bluetooth, activate "Developer Settings" and DISABLE Absolute Volume.
I'm on an Android, so I'm not sure if that'd work for iPhone users. But this made it possible for me to have a better volume adjustment gradient. NOTE: make coarse adjustments using your phone's volume and fine adjustments using your Rivian. Once you find a 'good' setting with your phone, you needn't keep adjusting. I think mine is set around 70-80% and that gives me the best range/variability.
Semibruce
Bruce
Oakton, VA
2023 R1S
Had the exact same issue. It's better after a hard reset, but I'm still in the single digits for most listening. Will try turning off the dynamic sound next.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
With what inputs? I only use Bluetooth and the built-in Apple Music, and both are fine and conversational at around 5 or so. I have dynamic on and EQ is not tweaked much. The fake surround is turned off.
suprteck
Anthony
Tesla Model 3, Rivian R1T
Mechanic
I have the same issue when using Apple Music. Volume 1 is too low and volume 2 is too loud. Needs more adjustments down low.
