In that case it comes down to vehicle efficiency and battery size. Using miles per hour instead of unit of energy per hour is always going to take into account how many miles the vehicle can go on a unit of energy.Oh. I was just referring to the max charging rates from the vehicle specs online.
Yep, they charge at the same speed. The Rivian isn’t slower. Like any truck it gets worse ”gas mileage”.Charon said it. The charging rate is the same between a Rivian and a Tesla: 11.5Kw. The Tesla has better range per kilowatt hour so the same number of kWh translates to different miles per hour charged.
Not an electrical engineer are you? As others have said the flow of energy is the same for both, it just takes more energy to take the Rivian a mile... You are gaining just as much charge even thought not as much range. To gain the same range per unit time, the Rivian would need to charge faster.Anyone understand why home charging is so much slower than a Tesla? It’s the same 11.5 kW charging, but R1S gets 25 miles and the model Y gets 44 miles off an hour of charging.
Sigh…..
It doesn’t take an electrical engineer to know that a glass of water and pail of water filled from the same tap won’t be full at the same timeNot an electrical engineer are you? As others have said the flow of energy is the same for both, it just takes more energy to take the Rivian a mile... You are gaining just as much charge even thought not as much range. To gain the same range per unit time, the Rivian would need to charge faster.
