not_a_car_guy
Massachusetts
R1T Perf Dual Motor
No, I heard some folks were having issues with resetting after the new update. I'm apprehensive to even attempt it.
I suspect the soft reset is vastly less risky than applying that update in the first place, but I agree it is probably not zero risk, so definitely your call on what you are comfortable with ;-).
SSteveEV
Spencer
R1T, etc
I am going to update right away when it gets released, I won't wait a single second, no matter if I'm driving, road tripping, parked at home or out of the country.
I don't know why. I just like the excitement and potential of a bricked truck.
For the most excitement, update while streaking with your clothes in the frunk.
SSteveEV
Spencer
R1T, etc
What can we do as individuals or as a community to stress how much we need to be able to do hands-free texting while driving? Out of all the OTA cool features and enhancements Rivian has published, how come we are still missing what I consider a safety feature?
Alan Ruck did his part. Your turn I guess?
(but also yes please send us this feature)
HeyEllwood
Keith
Bay Area
Model Y R1S
Operations Analyst
Damn. Can’t wait for them to fix the forward collision warning so my Driver+ will actually work.
They already replaced the module which they thought would fix the issues and warnings but it only fixed the ability for the car to view lanes and vehicles on the road and a few other things.
Rafael
Mandeville, La; Santa Rosa Beach, FL
www.lagniappeon30a.com
2021 Ford Bronco 2 door; 2022 Rivian R1S
Anyone else's settings menu option disappear with the last update?
Some reason your "recently used not favorite" app is being hidden. Try hitting anything in the swipe up menu and you should get access to the settings app again in that same swipe up menu.
HeresRonnie
Gambler
I’m still predicting a media streaming(YouTube/netflix)update for Christmas. Overall this is a solid update and I love that Rivian keeps them coming. This is exciting.
Redline
Edina, MN
I hope they bring Twitch and maybe Prime as well. Would make sense with Amazon and all. Either way, looking forward to it.
Inhisname
Craig
RSM
Next update details …..
https://rivian.software/2023-46/
Check out these new features, improvements, and bug fixes found in Rivian Update 2023.46
Highway Assist – Auto Reengagement After Lane Change
Highway Assist now automatically reengages after you change lanes.
  • While Highway Assist is active, use your turn signal and then change lanes.
  • When you center the vehicle in the new lane, the turn signal turns off and Highway Assist reengages automatically.
Navigation – Add Stops Along Your Route
You can now add multiple stops along your route and during trip planning for a customized navigation experience. Also, you can use the Rivian mobile app and Google Maps to send a multi-stop trip directly to your vehicle.
  • Before you go or during active navigation guidance, on the center display, choose Open to open your Trip Details with the option to Add Stop.
  • During active guidance, choose Add to add your next stop
  • There are multiple ways to edit your trip:
    • Swipe to remove a stop, or choose Delete when you are editing your trip.
    • Drag to reorder stops.
    • Choose Edit at the top of the Trip Details screen to edit your trip.
  • You can also add charging stops, which are shown as lightning bolts on the map. Select a charging location and choose Add Stop.
Mobile – Add Stops And Save Trips
Now with the Rivian mobile app 2.5.0 and later, you can plan multi-stop trips in advance, save them, and send them to your vehicle.
  • To access these features in the mobile app, go to the Explore tab.
  • Go to the map to create a trip or choose Add in the Saved Trips section.
  • Choose Save to add a trip to your saved trips.
  • You can now add stops to a trip by choosing Add stop.
    • Drag-and-drop to reorder stops.
    • You can also swipe left to remove a saved trip.
Clear Vehicle Settings
For your privacy, Clear Settings removes personal information and preferences from your vehicle. It also reverts user settings to default factory settings.
  • To access this feature on the center display, go to Settings > Service > Clear Settings.
  • To learn more about transferring vehicle ownership, scan the QR code in the Clear Settings screen.
Service Mode
Service Mode makes it easier for service technicians to perform maintenance on your vehicle. On the center display, go to Settings > Service > Service Mode.
Additional Improvements
  • Charging
    • Fixed an issue with the vehicle restarting scheduled charging after it was manually stopped.
    • Fixed an issue in which a charge session shows as completed before reaching the user-defined charge limit.
  • To avoid splashing passengers when entering or exiting the vehicle, now the front wipers temporarily pause while the vehicle is in Park and either front door is open. Wipers resume when the doors are closed.
  • Fixed a rare instance in which the Brake Region button in Drive Modes didn’t display setting options.
  • Fixed an issue in which the center display showed an incorrect screen when exiting seat calibration.
  • Fixed a rare issue in which the vehicle location in the Navigation app inaccurately jumps forward when the vehicle is slowing to a stop.
  • Fixed a rare issue in which the Mobile app incorrectly shows the doors as open and the range as zero.
  • Infotainment
    • Fixed an issue on the center display in which the phone panel didn’t disappear after ending a call.
    • Fixed an issue in which the Play button on the Media panel doesn’t respond when the queue is empty.
    • Fixed an issue in which, after restarting the software, the Radio panel is blank until you select a radio station.
    • Fixed a rare issue in which declining to sync contacts during Bluetooth pairing doesn’t dismiss the Loading contacts message.
This is great news. Any idea when the software will drop so we can upload it? I just checked and it doesn't show any update available yet.
Hillbilly
Earth
Boat and tractor
Hillbilly
Nope
