tate16t
Robert
2023 El Cap Granite R1S
Car Enthusiast
I just got home from a trip (Rivian stayed home) and was able to do a quick test. Got in and Apple Music played since I was connected to my home WiFi. I turned Wifi off, music stopped and a popup appeared about signing up for C+. I switched to my iPhone WiFi and music started again.
SamDoe1
Minnesota
Rivian R1T, BMW M2 Comp
How do you change the compass display to show a heading rather than just the NSEW and street name?
IGR
I make things
While this may not apply to most, I had my 12 volt battery replaced this morning. And technician made it so I get the update earlier, according to him, it has 12 volt battery related improvements.
Installing now…
thank you Rivian for taking care of your customers
EVentually
Audi S5, Rivian R1T
Begrudging connect+ subscriber here - got my update yesterday
Chinna
Naren
Albany NY
RIVIAN R1S, MACH-E4X
Software developer
If this is true, update will be stopped until fixed
Go into your Garage door settings and either re-trigger the location option to off/on or reset the home location / re-learn.
That will bring it right back.
Should not need to reset, just triggering the switch for easy access off/on cleared it up for me.
elektrode
Bran
NC
Honda Ridgeline to R1T
Paid The Man for C+ and got the update.
Fixed: GPS and red battery exclamation (that they broke on 2024.35)
Broke: Drive Cam can’t read memory stick that has worked for months. Both resets and multiple tries to setup again. None worked.
They are struggling with these bugs.
Cycliste
Solano County, California
Amateur aero weenie
IGR
I make things
I am also having issues with my older memory stick. Car doesn’t even sees it plugged in now.
But NVMe type SSD still works.
norivian
norivianyet
Cali
Gen 2 R1S 2025
Gen 1 without C+, still waiting. ?
Check your update menu in the car. Been wondering about mine too and i noticed .31 was there waiting for a manual install. I didn’t get any prompts from the app or the car.
CabinCrusher
Sean
St Paul, Mn
2018 JLUR
Project Manager
Nope, but thanks for the tip. ?
