mpshizzle
Utah
2025 R1S Dual Max (Baymax)
There's been a few threads started documenting people who have done the dual performance upgrade, and their thoughts on it. But thus far, nobody has shown the process or how it works. So I figured I'd screen record and show you all here!
Before the Upgrade
I did some 0-60 tests using a drag race timer app to see if I could get a before. That was the biggest waste of time EVER. The app told me my 0-60 was anywhere from 3 seconds to 6, topping out at 93.... Which was not the case. So..... yeah.
What I can say that AP Standard height, normal stability didn't feel any different from AP Low height reduced stability.
Buying the Upgrade
Finding the upgrade feels a little half baked to me. The "upgrades" section on the infotainment screen is very clearly designed to house upgrades like this. But as of right now, only connect + shows in there. The only way to get to the upgrade right now is by going to Manage Account -> Upgrades on the app. VERY buried and unintuitive. The only reason I knew to go there was from the email Rivian sent out about the upgrade. Once there, it was an easy enough process
Installing the Upgrade
You may have noticed that at the end of the screen recording that it said the upgrade would be available within 24 hours. I also got an email at that point saying the same. I was surprised to see that it actually requires software to be downloaded and installed. I figured the software was already there, but it would just besome sort of vehicle restart to enable it. But not the case. Fortunately when I went to the software update screen it was already there. Of note, I was sitting in the vehicle, away from wifi the entire time. No sleep or wifi required to queue up the update.
Rivian R1T R1S How Does the Dual Performane Upgrade Work? (Here's the Process & My Review) 20250325_193410
I pushed install immediately, because patience is my number one virtue 😆 . After about 5 minutes, the vehicle rebooted and I was greeted with this:
Rivian R1T R1S How Does the Dual Performane Upgrade Work? (Here's the Process & My Review) 20250325_193805
Rivian R1T R1S How Does the Dual Performane Upgrade Work? (Here's the Process & My Review) 20250325_193818
Rivian R1T R1S How Does the Dual Performane Upgrade Work? (Here's the Process & My Review) 20250325_193824
And that was it! Very easy and fast!
My Thoughts on the Upgrade
Even though all of my "scientific" 0-60 measurements failed miserably, I didn't need the numbers to feel the difference.
The first thing I noticed was in All Purpose mode. It was IMMEDIATELY noticeable that it was a bit peppier. Not a mindblowing, shocking difference. But even so immediately noticeable. So I can definitively say AP is NOT the same between Standard and Performance (also confirmed via an email from Rivian)
What WAS shocking, though was sport mode. WOW... Insane how much more power got unlocked from the same motors that were already there. When taking @cpucrazy (who has both a dual and a quad at home) for a spin, his words were "That feels like the quad!" Obviously, the quad (and tri) are still faster, but as far as the feeling of acceleration, it doesn't feel far off from those when you launch.
Where I did notice a bit more of a difference from the tri/quad is on the freeway. It was noticeably quicker at highway speed, both in AP and in sport, but still not to the level of tri/quad.
So overall I'm VERY happy with the new, unlocked performance. Even if I'm not in sport mode it makes a difference. But I will definitely use sport mode a fair bit. This upgrade is not for everyone, but for those that want it, it's spectacular.
As a side note, for those comparing to Tesla's "acceleration boost": The difference in performance of AP before an after is more ore less equal to what acceleration boost does. The difference in performance between Standard AP and Sport is FAR beyond "acceleration boost".
Other side note - I appreciated that in ALL of the GFX shown thorught the process, both on the phone and in the vehicle matched my actual R1S
---------EDIT-------------
I forgot to add - there is an interesting thing I noticed on the "About" screen post upgrade. Instead of saying R1S Performance Dual Max, it still just says "R1S Dual Max". Then at the bottom of the about screen it shows performance as an upgrade.
Curious if anyone with a factory optioned Performance Dual can confirm - did they change how it's displayed on yours now, to show like this? Or is your screen the same as before and they're differentiating between vehicles that got the software from the factory vs later upgrades. If that's the case, that would be interesting indeed, given that there are no physical differences.
Rivian R1T R1S How Does the Dual Performane Upgrade Work? (Here's the Process & My Review) 20250327_173511
Rivian R1T R1S How Does the Dual Performane Upgrade Work? (Here's the Process & My Review) 20250327_173518
Rivian R1T R1S How Does the Dual Performane Upgrade Work? (Here's the Process & My Review) Screenshot_20250327_173623_Rivian
mpshizzle
mpshizzle
Utah
Whoops! Forgot to actually attach the screen recoding. It's up now, though!
Southern R1S
2023 R1S (LE/GW/OC/20"AT), Lexus GX 460 Luxury
Builder
Posting solely for purposes of thanking you for posting this content in-line, rather than making a post that only contains a 45 minute YouTube video designed to drive clicks & ad revenue.
Top tier content (particularly on the walk-through of screen shots and screen recordings) to help those on the fence and appreciate you taking the time to do this.
Rividiculous
New York City
2025 R1S, 2006 3 series
Before the Upgrade
Buying the Upgrade
Great write up. I also upgraded and fully agree with @mpshizzle. The only thing I would add is that I also simply enjoy having the rear motor engaged in sport mode. The R1S handles better (or at least feels like it handles better) even when not gunning it.
Jonger1150
Jon
Howell, MI
Nerd
The difference between the QUAD and DM PERF is on the expressway between 80-110.
From 0 to 80 it feels very similar. The Tri and Quad have more power in those higher speeds.
That's my take.
mpshizzle
mpshizzle
Utah
Edited the original post - I noticed an oddity with how the performance upgrade is displayed on the "about" screen
HaveBlue
Rivian R1T R1S How Does the Dual Performane Upgrade Work? (Here's the Process & My Review) 1000032377
PaythePiper
Phx AZ
Model Y, R1S Dual Max
I still feel the Dual Max should’ve come with the specs of the Performance upgrade, especially $100k like mine was. $5k is a tough pill to swallow.
MikeWilliams_R1T
MICHAEL
Knoxville, TN
R1T, Chevy Bolt, Toyota Rav4
Government Sales
Good write up. I upgraded mine this week and noticed All Purpose being a little peppier as well. I was not expecting that. Somebody had posted here that the 0-60 in all purpose went from 4.5 to 4.1.
I am very curious about the two new off road modes and might give those a try this weekend. I guess I need to find the right trail within an hour drive of Knoxville to give rally mode a try.
Gotta pay to play. Or also known as paying the piper haha.
Cte515
Casey
Houston
Medical Device Sales
Ah, F@&$ it, I pulled the trigger today and upgraded to the performance, I might not use it a lot, it’s party trick, not needed, all that is true…..but I did it.
Damn, it’s crazy quick now. Incredible.
mpshizzle
mpshizzle
Utah
HEEYYYYY - congrats on the upgrade! I'm pretty happy with it
