Which drive mode is optional for this? Rock crawl?Saw this video of an R1T saving the day!
"Pull Another Heffer" mode *nods*Which drive mode is optional for this? Rock crawl?
Heck yeah! Made my morning!!!Saw this video of an R1T saving the day in Normal, IL!
The semi driver does appear to have the truck in drive so the Rivian would only have to pull it forward enough to get the rear tires to bite. Still would require some HP to do that!Let’s assume that is a legit recovery and video.
That semi is at minimum 18k lbs.
I have 2 of these in my fleet, 17922lbsLet’s assume that is a legit recovery and video.
FOR SURE within their rated towing specifications..... and I guess Toyota is claiming this ....
I’d like to see a Prius tryYea, I'll say that the video is cool and great to see Rivian getting the exposure, but like said above, the whole plane/truck/train pull is misleading. Around here they have a charity event every year at Dulles airport where they pull the plane. That said, note in the video that it is on a wet surface, the semi is a little off camber as is the rivian... it isn't nothing, but not a miracle either..
https://www.specialolympicsva.org/virtual-plane-pull
