vinniehobart
Vinnie
Normal, Illinois
R1T and R1S
Electric Vehicle Instructor at Heartland Community College
Our Students at Heartland Community Colleges Electric Vehicle Energy Storage program got to play around with the Rivian R1 Dampers today to see what are some possible failures with Air Leaks and how the seals operate and function. Pretty neat to see how simple an Airbag could be replaced if failed or a seal leaked instead of spending big $$ for the part IF you could parts for it. I believe Monroe makes the assembly so I wonder if you could get O-rings and Seals for it.
Fmc
Louisiana
2010 wrangler, 2023 R1S
@vinniehobart what do you expect the average life of the current air suspension to be? 10 years? Yes i know the real answer is until it breaks..
freshpow
My air suspension lasted 4 years and 70,000 miles.
Hope you picked up an extended warranty! Do you recall the total cost to replace?
MountainBikeDude
Vancouver
As a co-worker would say. "It's not the years, it's the milage"
It really comes down to how much abuse and how many times the suspension is cycled
rodbrock
Rod
Web/IT
I've had the rear dampers replaced twice by 25K miles. Most recent repair, all 4 dampers, hydroaulic lines and the hydraulic pump. Catastrophic failure. I live on an unpaved desert road. Total of 5 miles out and back to my home. This suspension system cannot handle it.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
Which mode do you run this in, and what settings for height/damping?
It’s got nothing to do with it not handling the load. Everything to do with poor QC by supplier: Monroe/Tenneco. Especially with units produced during COVID. During which all manufacturing suffered supply and labor problems.
rodbrock
Rod
Web/IT
Almost always change to Rally/High/Soft when on the unpaved then back to All Purpose/Standard/Soft on paved.
rodbrock
Rod
Web/IT
Ok sure, but what's the difference at the end of the day? If the quality remains the same, then system cannot handle it and will fail.
There are R1s still on original dampers. Explain that.
rodbrock
Rod
Web/IT
Wow, so defensive. I'm not bad talking Rivian here but I'm on my 4th set of rear dampers in 3 years of ownership. 40K miles. I'm really happy to hear that most other Rivian owners have never had their dampers replaced. I really hope it doesn't turn into a recall situation. These parts are wear items to begin with anyway. Clearly, subjecting this suspension to unpaved road conditions consistently accelerates the wear, in my case. I simply cannot recommend owning this vehicle without a warranty. That last repair was over $10K and required a tow.
