KBabione
Kevin
Lititz, PA
2023 R1S Quad (8/23)
Just started my install...Spent a very frustrating 15 minutes before I tried a T25 driver and the trim screws came right out. We picked our R1S up in August 2023 in case it helps anyone.
Gurule92
19 Tesla Model X Raven & 22 R1T, Adventure, QM, Glacier White.
Cyber Stuff
Did you not use the little tool in the box?
Gurule92
Cyber Stuff
Gurule92
Cyber Stuff
KBabione
Kevin
Lititz, PA
I tried for about 10 minutes with his tool, but it's a T20 and, for reasons only Rivian knows, my footwell cover was installed with T25 screws! As soon as I found and used my T25 driver I was fine.
Your video was helpful - Thanks for posting it!
technerd
SE PA
2022 Bronco, 2022 R1T
Tim-in-CA
So Cal
Gen 1 R1S, Lucid Air, T-Bird
Looks like so far so good for the most part for CP users. @EV Play - Alex, if I placed an order today, what would your estimate be for shipping. Just a ball park would be good. Also, someone posted tracking info and it appears that you are shipping these from OC. Is there an option to just come and pick it up when it is ready? Thanks!!
gokcabaga
I’m looking at EVPlay but holding off because of the Android Auto audio balance issues. Here’s how I think it could be solved cleanly:
  • Per-phone mixer profiles – EVPlay saves each phone’s call/media/Assistant levels and auto-restores them on reconnect.
  • Smart defaults – A release-installed database provides starting profiles for common phone/OS combos, that improves release over release from crowdsourced data about phone/OS-to-profile mappings, autouploaded when opted in.
  • Simple UI with three sliders for Calls/Media/Assistant. Reset/import/export for those who want to tweak.
This enables families and lets the experience for new phones/OSes naturally improve over time without needing manual effort from the EVPlay dev(s).
KBabione
Kevin
Lititz, PA
Just get EVPlay, install it, and work with Alex to get your requested changes made. You don't have to use it all of the time - I only use CarPlay for longer trips. When I'm local I just stick with the Rivian UI.
