AWD mode?
jotam
Bellevue
2025 Rivian R1S Max
Mine is the gen 2 DM R1S Max. I have noticed it stays as FWD for most of time in All purpose mode. Anyone like me wish Rivian will have a all time AWD mode for all the DM R1?
mpshizzle
Utah
2025 R1S Dual Max (Baymax)
I don't mind it too much, it's kicks on the rear motor when it needs to. (I do wish that there was less of a delay occasionally, but for the most part I don't even notice)
Snow mode will keep it all wheel drive all the time which is important for snow driving. If you have a performance dual sport mode also is all wheel drive all the time.
For All purpose highway driving, I don't mind one bit. Lots of extra energy efficiency with the only trade-off being a slight delay in full power that I only occasionally notice
BrianB
Conroe, TX
2025 R1S
I think it is AWD, unless you put it into conserve mode.
R1Tom
Wisc
Riv R1T
That is how G1 QM work...which I like the most. Let the driver select if they want the efficiency add of running around in wrong wheel drive for efficiency.
R1TandMe
Depends
R1T, Corvette, Audi A7, HD VRod
Retired and loving it
Not for the dual motor, defaults to fwd in normal/mild driving
egar
Minnesota
2025 R1T
I found that if you put it in reduced traction control setting that the rear motor is more active under normal to light acceleration. I don’t know if that actually makes any noticeable difference in traction or performance, but it is visible on the display.
iamnid
Mercedes EQE, Rivian R1S
Is there Sport on non-performance DM? Vaguely recall they don’t have it.
There are 3 modes only on non performance dual motors: All Purpose, All Terrain, and Snow.
I've noticed I get a pop-up message occasionally, mostly when using lots of sudden regen, that says "switching to all wheel drive."
jotam
Bellevue
2025 Rivian R1S Max
I don’t mind the energy efficiency too much. I want full power all the time. What I don’t like is I paid for dual motors but I am getting a FWD SUV using single motor most of the time. I just wish Rivian can give us DM owners a choice.
Sounds like you didn’t understand what you were getting yourself into. If you did, you would have gotten a Performance DM or QM. This one is on you. Rivian was clear on what modes are available for each of the drivetrains.
jotam
Bellevue
2025 Rivian R1S Max
Thanks. I tried it for a week and yes seems like it would be the workaround for now. Did yours always default back to Stability On every time you drive?
Hopefully Rivian will add a designated AWD mode for us in the future.
egar
Minnesota
2025 R1T
Yes, I think so, but I did not pay close attention. I’m just letting it default to whatever Rivian coded it for. I don’t have a strong opinion about what would be “best” — I’ve only had the truck for 3 weeks, so I’m mostly just observing and learning at this point.
