Best drive-cam flash drive recommendations?
mcarver316
MD
2025 R1T | DM LA Silver | Large Pack | Max Payload 2183 lbs
Analyst
Well that's not good. What happens if you connect it to a PC? Do you see the streams? If not, you might try formatting it exFAT on a windows device and then running the setup process again.
Thanks- reboot fixed the problem
goodoljake
Too many
Good morning,
I built my own using
SAMSUNG 980 PRO SSD 2TB PCIe NVMe Gen 4
and a heat sink case for $130:
Case: $10 with BF sale and coupon
Amazon.com: ORICO M.2 NVMe SSD Enclosure, USB 3.1 Gen 2 (10 Gbps) to NVMe PCI-E M.2 SSD Case Support UASP for NVMe SSD Size 2230/2242/2260/2280(up to 4TB) (M.2 NVMe) : Electronics
2TB PCIe Card: $120 BF Sale, no coupon
Amazon.com: SAMSUNG 980 PRO SSD 2TB PCIe NVMe Gen 4 Gaming M.2 Internal Solid State Drive Memory Card , Maximum Speed, Thermal Control MZ-V8P2T0B/AM : Electronics
Installed and working, but no long-term verification. All I know is I got really tired of erasing my Tesla Flash Drive all the time so I wanted to get maximum memory but not sacrifice quality or break the bank.
This will help to keep the USB socket in your center console from getting damaged when retrieving items stored inside the center console. It tucks in nice and tight against the back wall of the center console, then plug it right in to any storage (NVME or 2.5" SATA drive) device.
https://www.amazon.com/gp/product/B0C77JDKBN
Rivian R1T R1S Best drive-cam flash drive recommendations? 1732476526255-2z
goodoljake
Too many
thank you.
I actually just bought this one from doing a broader search. Transfer rate is lower, but I expect it to work fine. BF sale and 50% coupon brought it to $6:
Rivian R1T R1S Best drive-cam flash drive recommendations? 1732479984279-1x
Amazon.com: USB C to USB C Cable, 60W USB C Charging Cable, Right Angle USB C Cable, Compatible with iPhone 15/15 Pro/15 Plus/15 Pro Max, iPad Mini 6/Pro 2021, MacBook Air/Pro, Samsung Galaxy S23, 1FT : Electronics
Rivianero
Brent
San Marcos TX
2022 R1T quad large
FWIW, this is what I ended up with as a Drive Cam setup after reading many of these posts and experimenting a little.
Components:
  • SAMSUNG PRO Endurance 256GB MicroSDXC (link) as recommended by several others.
  • Anker MagGo USB-C Adapter, SD Card Reader (link)
  • Magsafe Ring Sticker (link)
Rivian R1T R1S Best drive-cam flash drive recommendations? PXL_20241206_145746552
This setup fits flush to the compartment wall below the USB outlet. The card reader has a flexible 90 degree USB-C cable and is designed to magnetically stick to the back of an iPhone. The metal ring sticker just keeps it quietly in place so that it doesn't dangle when driving.
Rivian R1T R1S Best drive-cam flash drive recommendations? PXL_20241206_150259379
So far working flawlesssly.
DayTripping
Timothy
DFW
Anyone have an idea of how many hours of recording we can get on a 256GB drive?
I put a safe in my center console and gave up some storage room so likely going with a flash drive and running the cable into my safe so a thief can't easily steal the evidence if they break in and know there might be one. Since the safe isn't huge, I don't want to give up too much space.
