Bluetti AC180 Power Battery Pack - Charging While Using
HyperionMark
South Dakota
R1T and Model Y (previously a 3 and X)
Just got my new EcoFlow Delta 3 Plus and it fits beautifully in the gear tunnel. Can charge at 100W from the 12V. Obviously I'll need to plug it in to the 120V when I'm boondocking, but the 100W from DC should be plenty for doing a charging stop with air conditioning.
mikehmb
SF Bay Area
I was just checking out the Delta3 Plus ... it's input limited to 1500W. Have you tried it using the on-board inverter to see if it trips the circuit?
HyperionMark
South Dakota
You can set the peak power draw anywhere from 100W to 1500W
KBabione
Kevin
Lititz, PA
2023 R1S Quad (8/23)
This sounds like you'd specifically need to put it into bypass mode to achieve what's specifically outlined in the text you're citing.
That said, I own a Delta Pro, so it's possible that there's a difference in function between the Pro and the Delta 2. My Delta pro does work exactly as you'd want it to: it'll recharge while still pushing AC to your devices. And you can control your load limit by customizing it to whatever you want (In my case, I set it to ~1200W to recharge from the truck). That said, if you set your recharge load limit to, say 1200, and your devices are pulling more than 300 at that point, it'll pull more than 1500. So, you set your load limit to recharge accordingly.
At least that's how the firmware behaved a few revs ago--I haven't recharged it from the truck in awhile. You'd be surprised how much you can power on ~3kW before you need to charge the thing!
Thanks - I picked up the Bluetti on a whim when the price dropped into that "let's give it a shot" range. The Delta Pro is a lot bigger (which is why you don't have to charge it often), and significantly more expensive. I'm only using this thing a handful of times a year and it's tough to justify anything bigger. All of the powerlines around us are underground (I'm in the Brighton development) so we rarely have any outages. I'm hoping that this setup will work for the next couple of years for camping and tailgating. If not, maybe I'll send you a PM and see if you'll rent your Delta Pro for a weekend every now and then...
KBabione
Kevin
Lititz, PA
Bravo to raising her correctly!!
Now if you tell me she likes Pink Floyd and tequila you might just have restored my faith in humanity ?
She does like tequila, but not sure about Pink Floyd. I've been blessed with 4 daughters (34, 30, and twins who are 18) and one of the twins just surprised me when I found out that her favorite musical artist is David Bowie!
R1Thor
Joe
Lancaster, PA
Mechanical Engineering Lead
Rent?
Rent?
Bro, as long as it's a weekend I don't need it, I'm happy to lend it to you for good vibes :)
It is a bit heavy.
Gives me good reasons to keep hitting the gym ?
KBabione
Kevin
Lititz, PA
I never gave this idea a single thought, but honestly it's a great one.
Thank you - I'll save you a little work...I have a Breville Joule Turbo sous-vide that draws 1100W max. When I did my testing it did indeed draw almost exactly that until my water reached my set temperature, at which time the draw varied from 0 - 700W (and the 700W was only for a second or so) to keep it constant. I also assembled a crude insulating blanket out of insulating bubble-wrap for my water container to try to minimize the heat loss.
The Bluetti has a "base" of 1800W output, but has a "Power Lifting" mode that allows temporary peaks of up to 2700W. Basically I'll leave the Bluetti plugged into the Rivian while I'm bringing my water to temp with only the sous-vide plugged in and once it's stable I'll unplug the AC and and plug in my assembled 400W power supply and then start using my other appliances like my induction cooktop or Blackstone 22" E-Series electric griddle. That should allow me about 45 minutes of power to finish dinner without worrying about tripping the Rivian inverter.
I'll post a trip report after our camping trip in April.
mikehmb
SF Bay Area
Nice!
Our Gourmia crapped out, so I picked up a knock-off on Amazon and actually rather like it. Much better set-and-forget interface, dead silent even with the circulator running, and sturdier. I'll measure energy draw later this week and report back.
Also need to figure out my induction stove situation. The electric element version I bought a couple of years ago is quite terrible, so I've been bringing the Coleman white gas as backup (and it always ends up as primary).
KBabione
Kevin
Lititz, PA
Perhaps I can save you some time here too...Here's my induction cooktop setup:
  • Nuwave Gold Cooktop - What I liked about this is that there's actually a "Watts" button that allows you to specify how much current you want to draw (600W/900W/1500W) and...
  • Nuwave Cooktop Carrying Case - I liked that it has a case available
  • Induction Cooktop Silicone Matt - I wanted something to keep pots from sliding...Amazon says it comes 2 to a package but I only received one (but didn't care because I only need one)
When glamping, I used to carry a full 25-lb propane tank to power my grill and my oven/stove combo. I'm not sure going electric has simplified things for me, but new is always fun. I also take an electric kettle (1500W) for heating water for coffee and hot chocolate.
mikehmb
SF Bay Area
Awesome thanks!
I always bring the Smeg kettle along for coffee / hot chocolate when car-camping as well - it's great. And of course a stainless steel French press. I pre-grind the coffee because I'm not a complete douchebag, and bringing an electric burr grinder would be next-level. We don't chop our coffee like savages. LOL
KBabione
Kevin
Lititz, PA
I almost spit out my seltzer when I read this! I pre-grind as well and put into ziplock bags - each one does a full thermos. This coming weekend about 60 people from our synagogue are going on a retreat at a camp that keeps kosher, which means that the coffee that's served Saturday morning was made before sundown Friday! Thank you, but no. People already know to come to our room for a decent cup - I'll likely go through 5 lbs of beans this weekend!
Snowdog
Steve
Iowa
2022 R1S LE
…chopping coffee like savages
Currently my favorite post on the forum. Having been reduced to chopping coffee like a savage many a camp session.
mikehmb
SF Bay Area
On the coffee hierarchy, I'm not sure which is worse - day old coffee, or instant from those little Starbucks packets. K-cups are on the bottom tier, sorry folks.
Having backpacked many many times with the Starbucks packets - I'm thinking I'd prefer day-old but Kosher coffee.
BrayBay
Paul
Launch Edition R1S - Forest Green/Forest Edge
So I did some more reading, and the Anker SOLIX F2000 (PowerHouse 767) has this uninterruptible power supply (UPS) feature:
Rivian R1T R1S Bluetti AC180 Power Battery Pack - Charging While Using 1742347403500-xo
The unit is rated for 2400W of AC output. The manual doesn't say explicitly, but I'm guessing the UPS feature would mean it can deliver 2400W regardless of what the AC input is delivering.
Rade
Rade
US - Rhode Island
radmorningcoffee.blogspot.com
I'm sorry, but camping to us is any hotel rated 3-stars or less.
