Charging on a 3 prong 240 outlet
KimBrennan
Vienna Virginia
Another consideration is that a 3 prong outlet means there may be no ground, and there have been reports of failure to charge (especially from the Rivian EVSE) when there isn't a stable ground potential.
On the NEMA 6-50 outlet, there is no neutral. In short, there are a lot of variations. Which is why there are so many different outlets.
Electrified Outdoors
Mount Airy, Maryland
EVoutdoors.org
Real Estate
Currently at a Campground, bought a TT-30(RV Plug/Nema 14-50 and the mobile charger won't power up. I've used the 14-50 plug that comes with the mobile charger with no issue at home, I've also used the 120v regular household plug on the Campground power outlet with no issue.
Either every 30amp outlet is not working on these sites (tried a few) or the adapter is bunk... Or the mobile charger is having issue with the 3-4 prong connection?
Anyone have any thoughts?
Also, I'm obviously going to lower the draw in the vehicle to closer to 20amps once this does work.
You need one specifically designed for EVs.
https://amzn.to/3Z0xO30
Rivifan
Chuck
Chicagoland
R1T, Infiniti QX60
IT Solution Architect
Thank you. Just got back from RV campground with same issue. Came here hoping someone knowledgeable had the answer, and sure enough...
I see one of the positive reviews on that product page is from an R1T owner, so order placed. Thnx!
EVoutdoors.org
Real Estate
I own and have used that adapter. It works well. Just make sure you check the line voltage before you start charging and check for voltage drop when you start charging. If voltage drops below 110 or worse yet below 100 it could cause neighboring campers to get angry. If there is already a lot of voltage drop you can reduce charging amperage as low as needed to help prevent problems.
Last year in Gettysburg I could only charge at 8amps ? . Crowded campground and old electrical system on the river prevented me from going higher.
Kitsap, WA
VSG
R1T LE/RB/OC/20
Dude, just look at where you are ... Spending a little extra time charging tomorrow morning is a small price to pay. Live and learn, but enjoy what's in front of you right now.
Oh, and while you're there ... don't forget to visit Exploding Whale Park!
