First Time Towing
nikhil726
Nikhil
New Jersey
Lexus
For anyone who has towed over 5,000 lbs load, was a weight distribution hitch necessary? I’m seeing that it’s required for anything over 5,000 lbs for both the R1S & R1T. If so, what weight distribution hitch do you recommend? Says that the Rivian can tow 7,700 lbs with a weight distribution hitch and 5,000 lbs without, I plan on pulling a load that weighs 5,750 lbs for reference. Towing a U-Haul car trailer from Atlanta to NJ!
DetroitRed
Derek
Belleville, MI
2022 R1T, 2011 Corvette Z06 Carbon Edition
I towed a car trailer about 1800 miles round trip with my R1T. I estimate the total trailer weight was 5000-5500 pounds, and I just used a regular $30 ball hitch without any issues. For just one trip, I wasn't excited to spend $300-400 on a weight distributing hitch. If you'll be towing that weight regularly though, it's probably worth it to follow the manual's instructions.
HaveBlue
The beauty of a car trailer is you can adjust the tongue weight for performance.
azbill
Bill
My boat and trailer are 5000 lb empty, and I am sure with gear it is closer to 5500. I cannot use a weight distributing hitch because it has surge brakes.
Electrified Outdoors
Mount Airy, Maryland
EVoutdoors.org
Real Estate
I would use a WD hitch. It makes towing as safe as possible. We have the fastway e2 trunnion. They make several different models depending on the weight.
https://www.fastwaytrailer.com/e2-hitch
Thedude
Alaska
You can’t use a weight distribution hitch with a uhaul trailer so problem solved. Adjust the vehicle’s position on the trailer to balance the tongue weight better.
nikhil726
Nikhil
New Jersey
Lexus
Yeah that‘s what my concern was or else I was planning on buying this:
https://www.harborfreight.com/10000-lb-capacity-weight-distributing-hitch-system-67649.html
You seem like you have experience with a U-Haul car trailer, do you know if it has mounting points or there are none so that’s why it’s not compatible?
nikhil726
Nikhil
New Jersey
Lexus
Also not sure if it helps with the tongue weight but I plan on towing a Porsche 911 RWD which has a rear engine so the weight might be in the rear to begin with, not 100% sure though.
EVoutdoors.org
Real Estate
Do you know if it’s compatible with a U-Haul car trailer by any chance?
Not off hand but you can contact their customer support. They are pretty responsive to inquiries.
You want the weight as close to the tongue as possible. Having a lot of weight in the rear is no good.
nikhil726
Nikhil
New Jersey
Lexus
I have called U-Haul customer support but they don’t even know what a weight distribution hitch is. I wonder if I can back a car onto the U-Haul trailer but don’t think that’s possible
LivingInKaos
R1T Launch Green Forest Edge
Most uhaul trailers tow very well, at least in my experience. The tongues are very bulky and there's generally no way to add the sway bars.
