Flat tire. No spare.
R1SFamilyGuy
NJ
Mazda CX-5
I do software things
Never changed a tire myself so sorry for the n00b question…
What’s a jack puck vs a floor jack? I thought all cars were the same and some jacks were more powerful than others
usulio
I can take this one. The jack puck is a little hockey puck that sits on top of the jack and kind of plugs into the vehicle. Rivian recommends using them in specific spots when jacking the truck. Most vehicles don't have this but I think Teslas do as well.
You can buy 3rd party jack pucks if you want to have them yourself, or check that the tire place you go to has them (Discount Tire supposedly does).
This is a jack puck:
Rivian R1T R1S Flat tire. No spare. ybkgnm3eoo091
R1SFamilyGuy
NJ
Mazda CX-5
appreciate it!
Rivian R1T R1S Flat tire. No spare. ybkgnm3eoo091-
I recognize the circular gap in the plastic panel from when I installed my running boards. Makes sense. Thanks!
so, all jacks are the same, more or less; jack pucks are vehicle dependent. Right?
usulio
Uh, like everything else I guess "it's complicated". Jack pucks are definitely vehicle dependent, if the vehicle even uses jack pucks in the first place. I only heard of Tesla and Rivian using jack pucks.
Each vehicle will usually have multiple possible places you can jack up from. Rivian recommends the jack puck option but says you could remove the plastic along the sides and jack from the frame rails. I think people have maybe used the control arms inside the wheels too. (not advice)
You are right that jacks themselves are not vehicle specific (like you don't buy a Rivian jack or a Tesla jack). But there are lots of types of jacks and not all jacks will work for all vehicles. There would be a lot for you to research there if you're curious.
Captain JB
Hermosa Beach, Ca.
Chevy Volt
Retired Airline Pilot
So then the pucks do NOT come with our jack and tire change equipment??? thx much
jeeden
Jeremy
Northern VA
Project Manager
You have a jack that is capable of jacking one wheel on the Rivian to change a tire with the spare tire kit. They do not offer you a setup for jack pucks to raise the entire vehicle off the ground into a rotation nor multitire change.
A lot of shops are going to drive on lifts that have swing out arms with different ends on them since so many cars have specific jacking requirements. A lot of shops will jack it up off the suspension (the lower control arm) is not something you want to do with a bottle jack or a scissor jack since the suspension moves and it can slip out. It's fine on a drive on lifts though
The whole thing really comes down to shops that know what they're doing and ones that do not. If you see a bunch of Porsches or other unibody vehicles with special Jack points going into a place and it gets good reviews they probably know what they're doing. If you go to jiffy lube or the bunch of airgun jockeys they're just going to lift the thing off of anything that looks sort of flat and plastic You're going to run into a problem.
