Hauling lumber with R1T?
jb0063
Jim
Philadelphia
I like this a lot. Is this the exact one you have? How's the overall quality? Seem brilliant and looks like it won't take up much room when not being used.
It's the exact one I have. It's pretty basic, but the quality is good. It even comes with the hitch tightener, a caution flag, and some reflective stickers that can be applied to the rack. The hitch tightener cinched the rack tube inside the hitch receiver, preventing it from rattling or moving around.
trez63
trez63
R1T, Gladiator, Porsche GT4, and a bunch of bikes
Good to know. I'm gonna pick one up.
Did you buy the version with the rubber pads or the normal one?
jb0063
Jim
Philadelphia
Blueassassin
Allen
il
Equipment Manager
But given that there are no rear tow hooks, it might be problematic...
Someone already did it with long pipes. You use the rear hitch tie offs. No drive shafts, no hot exhaust just drive over it and load up.
CharonPDX
Charon
Cascadia
InfoSec Geek
I ended up in getting one of the Loadd Sheett (long version )
https://loadd.co/collections/bed-extenders
Works great for keeping 12ft secure; also works great for things like plywood / drywall / server racks, whatever you want to haul that's too long.
I recommend adding on the flag option as well; make it super convenient.
and comically on their page if you look at the images you'll see a rivian with 12' lumber:
Seconded. I have done this on multiple occasions to haul 12' lumber.
MountainBikeDude
Vancouver
Lumber, concrete debris, dirty diapers, gravel, crane equipment, waffles.... It does it all!
Rivian R1T R1S Hauling lumber with R1T? received_1072621787458764
Rivian R1T R1S Hauling lumber with R1T? received_974111210711063
Rivian R1T R1S Hauling lumber with R1T? received_593550029244054
Rivian R1T R1S Hauling lumber with R1T? received_1495584918034397
Rivian R1T R1S Hauling lumber with R1T? IMG-20230512-WA0011
Rivian R1T R1S Hauling lumber with R1T? IMG-20230512-WA0003
Rivian R1T R1S Hauling lumber with R1T? IMG-20230821-WA0035
Rivian R1T R1S Hauling lumber with R1T? IMG-20230528-WA0002
Rivian R1T R1S Hauling lumber with R1T? 20230831_142343
Rivian R1T R1S Hauling lumber with R1T? 20240508_112039
trez63
trez63
Damn! You're braver than I am. Are those 16-footers?! That doesn't look like it would stay put on my hill (15% grade).
MountainBikeDude
Vancouver
12's so only a 5' overhang ?
OUTAGAS
Tommy
Irmo, SC
Owner of solar energy business
I knew from the beginning I would need it. I haul 10ft material weekly for work. I just got creative and retro mod a rack on the back. I have Had it this way for 2 years now
This is what I’ve been wanting to do. Can you provide details?
EVnewb
Dustin
Clarksville, MD
Sienna, Tesla MYP, R1T
Seems like a genius idea. Kinda pricey but might pick one up. I’m looking to haul 16’ 2x6 and I doubt this would work for that though.
I hauled 2 16’ 2x10s and just used ratchet straps up to the rear rail tie downs. I also went back inside and bought a 27 gallon tote to set on the end in the bed and strapped that down to the lower anchor points in the bed to hold that end down. I had another strap wrapped around that end under the tote to prevent lateral movement as well as one wrapped around on the tailgate. Everything worked just fine for my trip home. I also hauled it at 9:30pm so there weren’t many cars out and about.
Rivian R1T R1S Hauling lumber with R1T? IMG_7611
fastwheels
Doug
R1T LE, C8 Z06, GT-350, Optiq
I too have the Loaad Sheett and have used it for hauling 12' 2x4 as well as my 12' and 14' kayaks.
Super easy to use and holds the loads solidly in place. Highly recommended!
W1SE
Jake
Vancouver, WA
2022 R1T Quad, 2024 R1S Max
Branch manager
Here is the Thread from when I did it.
it’s not a super OEM look but I use the heck out of it. And it comes off in 5 min if I need more aero or taller bed space.
MountainBikeDude
Vancouver
Rivian R1T R1S Hauling lumber with R1T? giphy (1)
Herb
Herbert
Ohio
911, John Deere, R1T max DMP
This is a 10ft load. for 12' or longer you would have lay the load parallel with the bed and strap it to the side lugs. The bucket/strap method will still work. I keep that bucket in the gear tunnel with straps and other small crap. Cheap, multipurpose, very sturdy and always on board. Just make sure you have good quality bucket so the force of the strap doesn't pull the handle through the bucket rim. This one's super strong from Menards and is a highly visible red.
Rivian R1T R1S Hauling lumber with R1T? 20240514_171434
RNFinCA
Southern CA
RT1
I believe I finally have solutions for everything long I want to haul. As someone else suggested, I bought the Loadd solution from the Peoria company. It works well for large, heavy loads. It is well designed and will secure everything within reason. However, for long pieces of lumber, the Mariner solution from Range Industries is great. Very well built and strudy. I can confirm it is perfectly level with Rivian's rack. I have yet to try a 20' piece of lumber but I have confidence it will work. Pictures attached.
Update: after a significant project, I can confirm I can easily haul 16’, 18’ and 20’ lumber on this setup. For plywood, I used the Loadd strap system which is just easier for wide pieces. But for all board lumber, the rack is very quick and easy. Much better than having pieces over 8’ hanging out the back end. Plus, I have received so many compliments on the look of the rack, I have decided to keep it on permanently. Hats off to Range for a very well designed, good looking solution.
Rivian R1T R1S Hauling lumber with R1T? Mariner Rack - 1
Rivian R1T R1S Hauling lumber with R1T? Mariner Rack - 2
