HELP Charging with generator
HighVoltOverland
Laguna Beach
GW/OC R1T | Tesla MY
Retired-ish
it’s interesting that the reader still says open ground even with the bonding plug
fhteagle
Near Telluride, CO
2013 Volt, considering R1S
So you connected the generator frame to ground, but is that frame ground point continuous with the receptacle ground pin?
Do you have any way check the AC frequency the generator is putting out? Some run fast (62+ hz) by design, especially while unloaded.
Thedude
Alaska
Here to report the two additional adapters do not work.
At this point I’m out of ideas. I may return this generator and try a different one that others have had success with.
It won’t work with that. You need an EV specific adapter to take the 120v single phase power and make it work using the truck’s 240v two phase 14-50 plug. I have used the following adapters along with a home made bonding plug and it has worked on every generator I’ve plugged into, including those that are not inverter generators with a clean power output.
https://www.amazon.com/3-Prong-Generator-Adapter-Converter-L5-30P/dp/B07RBTPH2F
https://www.amazon.com/Parkworld-885378C-Adapter-TT-30P-14-50R/dp/B07MD41D45
jemkewl
Still have an open ground... Assuming the portable charger does not like that...
I see the grounding pole from your generator, if you have some loose wire you might be able to connect the ground wire to any ground around. Maybe wrap it around a long nail and stick it into the ground.
Not necessary, this will do nothing.
Hyfly
Hyfly
Idaho
2025 Expedition - 2022 R1T
I ended up returning the generator and got a different one ordered.
I plugged into my dads and it worked first try so assuming that specific generator was just not compatible with the Rivian.
Hyfly
Hyfly
Idaho
This is the one I’m trying this go around.
Limited-time deal: Westinghouse Outdoor Power Equipment 4500 Peak Watt Super Quiet Portable Inverter Generator, Remote Electric Start with Auto Choke, Wheel & Handle Kit, RV Ready, Gas Powered, Parallel Capable https://a.co/d/2LKapYC
jemkewl
Not 240v... Good luck!
Thedude
Alaska
Hey I prefer 240v if you have a good recommendation. Right note just trying to get something to work!
How large of a generator are you looking for? The Harbor Freight Predator 9500 is a good 240v generator that works for EV charging and is affordable.
Hyfly
Hyfly
Idaho
Yea I’ve really thought about that one. It’s just roughly 260 pounds. Would like a bit lighter as it will be getting hauled around on adventures.
fhteagle
Near Telluride, CO
So I just ran another test with my own B&S 5K generator (it needed maintenance anyway), rebuilt / repaired 10 year old clipper Creek built portable L1/L2 EVSE, my Volt and also a '23 model Y.
Key takeaways:
- Generator needs to be up to speed and reasonably warmed up
- Power switch needed to be off or the J1772 need to be unplugged, trying to "hot start" straight to charging stalled the generator
- The voltage was all over the place from the generator, even with it throttled up as high as it would go. Volt didn't care, but the Model Y needed pulled down to below 8 amps to keep the ripple to less than 5 volts. Ugly ugly power coming from that thing.
But it did work. You ever figure yours out?
Hyfly
Hyfly
Idaho
Key takeaways:
I was able to get a different generator working. Only at ~4 mph though. Was hoping for more.
IHScout
Waid
Phoenix, AZ
Chevrolet Volt, Expedition
