MartinW
- First Name
- Martin
- Joined
- Jul 16, 2023
- Threads
- 1
- Messages
- 8
- Reaction score
- 3
- Location
- Grand County
- Vehicles
- R1S
- Occupation
- None
- Thread starter
- #1
Here is a chat I had with Rivian support. Others who charge in a heated garage with a Level II charger but venture out into cold temperatures, might find it interesting:
Chat started: 8:39 AM, January 25
Thank you for contacting Rivian Service Support and Roadside. This is Mohammad, how can I help you today?
Hello, I have a question regarding the Cold Weather Tips email I received yesterday
In it, it said 'Preconditioning the vehicle before drives, especially in the cold, can help improve performance, range and efficiency.'
I charge at home in a heated garage usually set to about 55 degrees. When I leave my garage it is frequently below 0.
Would I benefit from pre-conditioning given that my garage is heated yet I am headed into cold temperatures?
Preheating via departure time would be another 'thing' I have to do, and would only want to do it if I knew there was a benefit. Is there anyway to get a definitive answer to my question rather than assuming?
Okay, thanks. I'll be here...
It is already comfortable. I have not experienced any issues with maintaining a very comfortable cabin temperature, usually 68 degrees, even when the outdoor temperature is -10 or lower.
Hey Martin, fantastic question, and although you're in a better starting position than someone who parks the vehicle outside in these colder temperatures, I would have to assume it would only benefit the vehicles performance to precondition. We haven't really been provided with guidance regarding preconditioning in a heated garage though, so the benefits may not be as significant.
I'm trying to gather a better understanding of this for you from some of my colleagues as well if you have a few minutes for me to try and find a definitive answer. I'm also looking through resources to see what I can find to provide you with a better answer than just an assumption.
Okay Martin, I've gathered some more information. So the reason the email asks to precondition the vehicle is so that the HVAC is not working as hard when you drive to warm up the interior if it's already at temp. When you leave the car without preconditioning, does the HVAC system take a while to heat up? Or is it already relatively warm?
In that case, preconditioning would not be required since the vehicle already maintains a warmer temperature due to being inside a heated garage. The process of the HVAC system working harder to get to a point where it's warm is what can have a significant impact on range/efficiency.
So the definitive answer to your question is no, preconditioning in your current scenario is not required.
