Looking for a flat frunk floor
diabolik
Sean
Punta Gorda, FL
Rivian R1S, Jeep JKU
Contractor
I am using a yeti roadie 24 in my frunk and it always annoys me that it can’t sit flat in the middle. Does anyone make an insert to make a flat floor in the frunk? Needs to sit on the bottom for maximum height.
any leads would be appreciated.
thanks!
shamoo
Rivian R1S, Porsche 911 GT3
Cybersecurity
From my experience, the frunk is pretty flat (top surface that folds down on the 1st gen). I have a rubber mat there and I can fit some pretty large boxed sized items in there.
Where is it "not flat" for you?
Are you talking about the inside when you flip the cover? Then yes, it isn't flat but most people use this to store little things like charging cables and whatnot. Due to the angles, it isn't very suited for something shaped like a cooler.
Rivian R1T R1S Looking for a flat frunk floor 1783528644207-ui
Otherwise mine looks like this most of the time and I consider it pretty flat.
Rivian R1T R1S Looking for a flat frunk floor 1783528711289-4o
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
Rivian R1T R1S Looking for a flat frunk floor 1783627430309-2
I wonder if OP is missing the flip-up floor? It's flat, isn't it? I can't open my frunk currently to look. I found it perfectly comfortable to lay in.
Rivian R1T R1S Looking for a flat frunk floor 1783627519978-zx
shamoo
Cybersecurity
Yep, it is flat. Just like my picture above, just without the rubber mat. Same size and shape.
Looks just like this. I think it is pretty flat.
