RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Jeep & R1T & Silverado EV
I will not be automatically sending them out.
My plan is the change, once verified, will be made as a running update to the existing model. It will be offered as a replacement part should people need to purchase a replacement.
Existing owners before the change will be contacted and provided with a coupon code to make the part cost $0. You'll then have to choose if you need or want the updated part and place an order for it.
FYI - The updated center block is now in significant production and stock is available to ship. If you were an early owner, check your email. A targeted email with a coupon in it should be delivered very, very soon. This coupon will discount the $8.00 replacement part by $7.99, making the upgraded item $0.01 + shipping, which starts at $3.60.
Shopify was being dumb (or I was, or maybe we both are?) and I couldn't make it free + shipping. Please accept my humble apologies about that.
Also, I think today is one of the first days where we had real availability of the product since it went out in the newsletter mid last week. While not difficult to print, they take quite some time. I'm continuing to pump them out as fast as I can.
909phillyman
Sean
Rivian r1S
Thank you for the update. I just ordered my set about 2hrs ago, but I also just received the targeted email about the updated part. I just wanted to confirm that I can disregard the email because I'll be receiving the updated center block, and will not need to purchase a 'replacement part'. Is this correct?
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
You sure can.
Edit - I believe this is Shopify being dumb. You were the last order and were errantly included within the group. I'm going to submit a bug report on about it. :(
Dave S
Dave
Sonoma, CA
Sorry, late to the game here. Are these still available? The Shopify site shows ‘back ordered’. I’m assuming that’s just because you’re producing them to order? Or is there a huge demand and backup on them?
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
100% still available. I think they're on the production plan for Tuesday or Wednesday. These take a bit to produce and we've been a bit swamped with producing a bunch of the NextGen Cup Holders and Ultimate MagSafe Charging Pad V2's that were both launched in the last 10 days.
I'll update the ETA :)
mkg3
R1S, Model 3, Outback, Artura
@RWerksman, Just wanted to provide a feedback how valuable this riser was recently.
We moved our son who just graduated college and got his first real job. We packed the R1S as much as we could. Having a flat floor sure made it easier.
Thank you!
Rivian R1T R1S R1S Cargo Floor Risers (For Flat Floor) -- my 3D print solution 1723156515116-45
Rivian R1T R1S R1S Cargo Floor Risers (For Flat Floor) -- my 3D print solution 1723156560016-x1
Rivian R1T R1S R1S Cargo Floor Risers (For Flat Floor) -- my 3D print solution 1723156620650-n2
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Thank you!
lirandy
Randy
Walnut, CA
2013 500 Abarth, 2018 Model 3, 2023 R1S
Will it be too late to buy a set? I just got my R1S and really think having a flat floor with 3rd row down is a good idea.
lirandy
Randy
Walnut, CA
I try to add the Ultimate MagSafe Charging Pad V2 in cart but it keeps saying it's out of stock :(
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
You should be all set now. Keep in mind that orders are shipped in the order they are received and we've been away most of the week, so it will be a few days before we're able to work through everything.
crispydurian
Tesla MY, R1S
what an elegant solution! do you know whether this will work with the 2025 R1S too? thank you!
Kelvn
Kelvn
Irvine
Made a rough revision for the center piece. This one bolts into place using the original screw holes and pivots on a pair of hinges to either store or use. This addresses issues people have with the center piece falling into the sub-trunk when lifting the floor. The two side L's wont fall over because of their shape.
Rivian R1T R1S R1S Cargo Floor Risers (For Flat Floor) -- my 3D print solution Image (22)
Rivian R1T R1S R1S Cargo Floor Risers (For Flat Floor) -- my 3D print solution Image (2)
Kelvn
Kelvn
Irvine
This one is a “one of” experimental/trial I made for fun to see if I can come up with “improvements”. It works but it’s much more complicated and a bit more fragile than the original design. I can see them breaking easier if someone knocked against it wrong or opens it with some force.
The ones @RWerksman sells are not these experimental ones.
aAlpine
Victoria, BC
2024 Quad R1S, Ioniq 5
Hey @RWerksman , will your updated models be uploaded to your Printables account?
Thank you and Kelvn for the work you've done on this. I'm looking forwards to being able to sleep in the back of my R1S without sliding down to one end.
