Low speed 'Tocking' when stopping or starting
Low speed drivetrain 'tock' when starting out or stopping? Would you contact service?
  • Total voters
    342
DaveA
Rivian R2 Launch Edition
I'm probably one of the most vocal people about being annoyed with the Tock, but there are times where I waffle a bit.
There are times where it honestly doesn't seem to be bad, and other times where it drives me crazy. It's especially bad in stop and go traffic even when using adaptive cruise control.
The last service visit they claimed it was "within spec" and they claimed they all had the tock to some degree. I asked them to show me on a new one or loaner, but they were unable to reproduce it on the loaner they tried it on.
I'm not sure what I should do at this point.
Ignore it as it otherwise is a good vehicle for my use case
Try to escalate it in hopes they fix it
The fact that new ones don't seem to have a tock pushes me to try to escalate it due to concerns that the tock will decrease its resale value. Why have a tock'ing one when you can have a non-tock'ing one?
My plan is to trade it in to Rivian for a new one at some point. So not that worried about it especially since powertrain is under warranty for so long. But winter is coming so that will shut it up for 3-5 months. Lol.
Kitsap, WA
Well, mine is back... They got rid of it after my service appointment and I had a week of silence. I thought it was something rolling around in the bed, so I emptied it and the gear tunnel, no luck. It only does it under heavy regen or acceleration though, so I try to feather and avoid it. It feels like unintentionally cracking a joint or knuckle each time...
cjbot3000
tucson, az
I'm not sure if this is mentioned, yet, but in my case it was clutch packs.
Is you put it in conserve the noise may stop (no clutch packs in front)
Each rear has a clutch pack that has to engage/disengage, which I didn't realize.
Mine were (bad?). They tocked excessively.
So far so good with new clutch packs, with minimal rocking. 2 wks on now.
R1Tom
Wisc
Riv R1T
I wonder if the tocking is doing any long term damage to the drive units? That repeated shock loading seems like it could be doing damage to gears and bearings, but not sure if significant. 8 year/175k warranty anyway I guess....
suprteck
Anthony
Tesla Model 3, Rivian R1T
Mechanic
My truck is at the service center now for the low speed tock. They already replaced the half shafts and ting washers. I can make the noise happen just by turning the steering wheel left to right at a stop. Sounds like it was coming from the steering rack near the front. But actually was coming from the subframe. They found a broken weld. Currently replacing it was the new updated subframe
DaveA
My truck is at the service center now for the low speed tock. They already replaced the half shafts and ting washers. I can make the noise happen just by turning the steering wheel left to right at a stop. Sounds like it was coming from the steering rack near the front. But actually was coming from the subframe. They found a broken weld. Currently replacing it was the new update subframe
Please report back if that fixes it.
Jonger1150
Jon
Howell, MI
Nerd
So 75% of Gen 1 owners have the tock?
Add me to the list. It's the half shafts I'm sure.
md2023
New England
Subaru
I have some of the low speed stocking - mostly at first when I get in the truck. In particular backing down my driveway. It doesn't seem to be an issue, but I am not knowledgeable about suspensions. Should I be worried?
Second question(s): When I first unlock/get in the truck (before shifting, even before I get in sometimes), there is a moderate "ting" noise (once). Almost every time. It is coming from the back of the truck but it is hard to say where exactly). Anyone experience this? Any idea what it is? ty
