MTB Tailgate Pad
BooneRiv
Jason
Boone
Tacoma, Tesla MS
I like this option bc you don’t have to strap anything to the tailgate to collect debris and block the light bar. This is on my daughter’s bike:
Rivian R1T R1S MTB Tailgate Pad 1654008519740
Rivian R1T R1S MTB Tailgate Pad 1654008545863
Rivian R1T R1S MTB Tailgate Pad 1654008582586
Rivian R1T R1S MTB Tailgate Pad 1654008624184
Rivian R1T R1S MTB Tailgate Pad 1654008661405
CommodoreAmiga
INACTIVE
INACTIVE
That looks like it has a high likelihood of denting the tailgate -- specifically at that crease/body-line. Be careful.
BooneRiv
Jason
Boone
Tacoma, Tesla MS
Almost all of the pressure from the straps is horizontal and the down force from the straps is mostly on the back (bed-side) of the tailgate. It’s very gentle on the body. Not the slightest scuff after driving on lots of curves and bumps in the mountains.
dduffey
R1T Quad LE, R2 LE
Has anyone else considered the half-stack versions of the pads? A quick search shows that Fox and Raceface offer them. Buying a second one for carrying two more bikes is only $9 than buying a full size.
95% of the time I only need one or two bikes. In theory Installing and removing the smaller one will be a little faster but it looks like they only have one less straps than the full size (3 vs 4).
Fox
Racface
I thought about it, but concerned there will be a gap when the tonnoe is closed. Maybe that is a bit OCD.
Wefty
Robert
Chicago
R1T, 2008 Fit
I'm supposed to get my R1T tomorrow so I ordered both of the pads I linked to above. I'll update next week.
Law
Boston
I am testing out some options for transporting bikes. This one is the 1Up. I am concerned about the negative effect on range. Also when adjusted to fit a large size 29" the rack extends past the lift gate. So far it fits all bikes I have tested.
Rivian R1T R1S MTB Tailgate Pad 1U
I also am testing the Yakima GateKeeper Medium. I think this will be more efficient and won't affect range as much.
Rivian R1T R1S MTB Tailgate Pad IMG_8342
Rivian R1T R1S MTB Tailgate Pad Tailgate Pad
I added some foam under the pad to protect the bike and tailgate.
Rivian R1T R1S MTB Tailgate Pad IMG_8341
I folded the inside corner to prevent it from interfering with the tailgate latch.
Rivian R1T R1S MTB Tailgate Pad IMG_8345
There is some interference with the strap clip when closing the tailgate with the gooseneck hinge filler plate. It's not that bad but good to know.
Rivian R1T R1S MTB Tailgate Pad IMG_8360
Of course I am still testing out my customers tailgate pad.
Rivian R1T R1S MTB Tailgate Pad IMG_8172
Rivian R1T R1S MTB Tailgate Pad Custom Pad
Rivian R1T R1S MTB Tailgate Pad IMG_8369
SJaYx2P
San Jose
Tacoma
I'm diggin the EVA version. I don't think the polylam would hold up as well. Specially in the corners.
aw113sgte
WI
22 R1t
I've tried lots of different options over many years, what I finally settled on is a North shore rack. Super adjustable, extremely strong, very well built with no plastic bits to break. It is a bit heavy but that's the only downside I've experienced. Keeps bed free for other stuff, very fast to load bikes. I can fit my kids fat tire bikes and my heavy ebike easily. Single and dual crown both work.
Rivian R1T R1S MTB Tailgate Pad 20220528_093241
Rivian R1T R1S MTB Tailgate Pad 20220528_093228
Wefty
Robert
Chicago
R1T, 2008 Fit
I received the Fox and Raceface halfsie tailgate pads and they are the exact same pad with different logos.
None of these thoughts are new. The pads don't fit very well and unless someone designs a Rivian specific one I don't think any pad will be that great. The tailgate is too thick and the middle tailgate panel interferes as shown in the pics above. The middle panel also makes installation more time consuming. One nice thing is that the tonneau doesn't seem to mind it when closing.
The lighting in my garage was horrible and my pictures are worthless.
RedDragon
Chicago
Tesla Model S, Jeep Wrangler
As I posted previously I have tried out the RaceFace and Dakine Pad. The solution below i like much better. For those of you that are worried about range, this would be a good solution i think.
It is very easy to pop on and off, although I plan on leaving it in as the tonneau will go over it and i can still haul quite a bit with them in place.
The bike pictured is about as big as you'll find for an MTB - XL 29'er. In one picture you can see the included extension rails, but these keep you from closing the tailgate and don't add much to stability so I think I will delete them (very easy).
I may add an extra cradle if feasible but need to test it out a bit first.
https://pipelineracks.com/
Rivian R1T R1S MTB Tailgate Pad IMG_0991
Rivian R1T R1S MTB Tailgate Pad IMG_0990
Rivian R1T R1S MTB Tailgate Pad IMG_0989
Rivian R1T R1S MTB Tailgate Pad IMG_0988
tomis916
Boulder, Colorado
2023 Rivian R1S
Have you tried lowering the rack with the bikes on to see if you can still drop the tailgate?
CGM55082
San Luis Obispo, CA
Tesla Model 3
PR
Thanks for posting this -- I love this solution. Question is, which model did you order? Looks like they have different models based on truck bed size. Many thanks.
RedDragon
Chicago
They have a sub-compact, compact, and full size rack. The rivian is a compact - the middle size.
dduffey
R1T Quad LE, R2 LE
Those look really nice! I need a spot for four bikes though, will contact them to see if they can make one.
