Engineering, Dog Petting
I had to do this 3-4x already and it only works for a day or so. The calibration is actually in the manual as well...pg 145
It's in the software manual as well.
camaroz1985
Carlisle, PA
R1T, ID.4
I tried this on mine, but it failed. Now I get a message everytime I start the truck asking if I want to calibrate. The "bonus" is the button outside does nothing now, so no one will hit it trying to see how it works and get it stuck (mine is currently closed and won't open).
Johny
Wallingford PA
06 Corvette Z06, 19 Chevy Volt
Electrician
Silicone spray will attract dirt. Rivian uses dry graphite.
It is a dry silicon lubrication spray. Its designed for this form of application. Its was stopping short and struggling upon delivery and after I sprayed the rails its worked flawlessly so far.
crashmtb
Man oh Manitoba
O ho, I thought it was just regular old spray silicone. Neat!
atebit
R1T, Porsche Boxster
I did this on mine, but now my tonneau closes all the way then reverses and opens about a quarter inch. The truck then thinks the tonneau is open so when I push the button inside the cab it tries to close it again then it just bounces back open. Seems to still need some work.
Mine did this at delivery. The mobile tech came ou, connected his laptop & was able to square it away.
Boges
San Antonio
Can and Truck
Fixed mine not closing all the way…for now.
Appreciate your the tip.
I feel like if the truck isn’t perfectly clean, the tonneau slates are eventually going to seize up.
walkingcrow
Patrick
Riverton, Wyoming USA
Tesla X 100D, Tesla M3P
IT Manager
This worked for me, 3 short presses and hold the 4th until it starts to move. now it opens fully for the 1st time ever.
Bernefj60
Davidsonville, MD
‘22 Rivian R1T, ‘21 GMC Yukon Denali, 78 FJ40
Commercial Real Estate Broker
I had an issue where the tonneau would close almost all the way, but leave a ⅜“ gap; just enough to let In rain. Service tech came out for a few things and he calibrated it (as per the above) but also recommended lubing the tracks after every wash. I use WD40 white lithium grease, which works well.
On a related note, has anyone noticed that the seal at the end of the tonneau is about ½” too short? I have a gap on either side, and i just noticed it after my last wash. Has anyone else had their seal shrink?
It's intentionally like that to reduce the likelihood of it getting sucked up into the tracks.
jjswan33
jjswan33
Joshua
Sandy, OR
IMO that is Rivian speak for they all are like that and we don't want to fix it. The gasket easily slides to one side or the other so if it was going to get sucked up in the track it would have happened to someone already.
Mine is not that loose. It doesn't really make much of a difference because the side corners have a giant space in them anyway.
ironpig
Los Angeles, CA
My tonneau finally failed over the weekend. I put in a service request. They said it will likely be awhile before my appt because they don't have the new parts yet. I'm going to see if I can do the reset and use the dry lubricant spray and maybe fix it temporarily myself. Might just see if I can get it to open all the way and leave it open until my appt.
camaroz1985
Carlisle, PA
R1T, ID.4
After the last update I was able to get my cover functioning (for the first time since delivery day).
Mine was getting caught on the trim above the cover (below the back window). I used the recalibrate function before and it still got stuck. I even got it to cycle fully one time by pulling rearward on the cover as it retracted for the recalibration. The problem was as soon as I tried to use it, it would get stuck on the first seam that came to the trim piece and would return to fully closed. It also had the "bounce back" that a lot of people reported. I ended up recalibrating and letting it fail the recalibration so that it would close tightly again and disable the button so no one would try to push it and have it bind up and possibly break in the open position.
I saw someone post that the newest update (2022.27.2) slowed the cover a little and it seemed to catch less on the trim that was my problem. I did the same thing again (pull rearward on the cover as it retracts during recalibration). It completed recal and much to my surprise it now cycles completely without stopping. It doesn't sound great and still makes some popping noises so I am not going to use it much until my service appointment (I assume for replacement) in the middle of September. The cover might move a little slower, but most notably, it slows down for the last couple inches of opening and closing and doesn't quite slam as hard into the stops as it used to. It also doesn't bounce back and leave the gap that it did on the 2022.23 software.
Just wanted to give an update in case anyone else was in the same boat, its nice to be able to have the open bed when needed. Didn't realize how much I was adapting my life to not having that option.
tplociniak
Todd
NE PA
R1T, VW Atlas
Construction Manager
going to bump a very old thread and say thanks for posting this information. my tonneau cover has been working well since delivery in 2022 but just recently it got out of whack with where the open and closed limits were. It would try to over extend at the tailgate side and then when opening it would stop with 1-1.5 panels still showing in the bed. The calibration worked great and back to normal now.
Kitsap, WA
Same! I reset mine for the first time in it's 3.5 years Sunday. I wonder if they all got a bad memo...
