CommodoreAmiga
INACTIVE
INACTIVE
If we go off of the 1,760 lb payload that was previously reported, the R1T could weigh as much as 6,241-7,240 lbs. That payload is no longer listed on their website, so who knows if it's still accurate.
EDIT:
Customer Service just confirmed to me that the payload of the R1T is "1,764 lbs".
This means that if the R1T is in the 8,001-9,000 lb range for GVWR, it's Curb Weight is more than we previously expected... at least 6,241 lbs... maybe more.
Are you accounting for passengers? That would lower the curb weight, if not.
thedole
Portlandia
R1T LE
Brewmeister
If the GVWR is within 1,000lbs for the largest and smallest battery, which I assume it is based on this info, we can possibly assume the maximum payload for a small battery pack R1T is higher than the max payload for the large pack.
KenJ
NJ
Tesla S85D
I was finally able to find Rivian's VIN deciphering document in the NHTSA database. This all but confirms the initial deliveries will be sold as 2022 model year, and includes some other interesting information. The R1S is not included yet.
PositionContent DescriptionAssigned Values
1-3​
World Manufacturer Identifier (WMI)​
7FC - Rivian, Vehicle Type: Truck
4​
Model Line / Body Style​
T - R1T 4-door Pickup Truck
5​
GVWR / Brake System​
G - 8,001-9,000 lbs.; Hydraulic Brakes
6​
Engine / Motor / Drivetrain​
A - Electric, Quad-Motor, AWD
B - Electric, Dual-motor, AWD
7​
Restraints​
A - 2x front airbags; 2x knee airbags; 2x front row side airbags; 2x curtain airbags;
2x front row 3-point seat belts; 3x second row 3-point seat belts.
8​
Trim​
A - Adventure
E - Explore
L - Launch Edition
9​
Check Digit​
Calculated based on values of remaining 16 characters
10​
Model Year​
N - 2022
P - 2023
11​
Manufacturing Plant​
N - Normal, IL
12-17​
Serial Number​
000000 - 999999
Interesting that they encode the trim level in the VIN. Feels like it’s been many years since auto companies did that or am I mis-remembering
Atlrivian
Atlanta
Grand Cherokee, XC90
Per fueleconomy.gov, the Dept of Energy updates the website weekly. So theoretically Rivian's official rating could show up there before Rivian tells us ?
Atlrivian
Atlanta
Pretty sure BMW still does this. 740 vs 750 etc
kanundrum
Washington, DC
I have a search flag on it with no luck daily, Id assume Rivian controls that information and will let DOE know when to publish unfortunately.
KenJ
NJ
Tesla S85D
Good point. Now I’m wondering when is it a difference in model, body style, engine vs an option package? I’ve got some research to do.
timf
Tim
Novi, MI
I have updated the first post with the R1S information filed on 8/11/21.
twinprice
Winston
Richmond, VA
Yukon XL Denali, Tesla Model Y, and LE RS1 - Hopefully!
That means I almost know my new RS1's VIN #! only missing a few numbers:
7PDSGABL_NN______
It's the little things! ?
davrow_R1T
Riverside, CA
2 Toyota Siennas
I wondered how the check digit is calculated. I was about to ask, but decided to look it up, instead. :)
The check digit is calculated by removing all of the letters and substituting them with their appropriate number counterparts. You then take those numbers and multiply them against a weight factor table. You then have 16 numbers which you add together and divide by 11. The remainder is the check digit. If the remainder is 10, then the check digit is “X."
I used the calculator here: VIN calc
So mine (R1T) is: 7FCTGAAL2NN007401 (well, maybe)
taylor710ce
MA
Mazda 3 and Highlander
Are vehicle's ending serial numbers typically designated by model or overall production sequence?
