Gen2R1T2025
I got the sensors blocked error few times. No snow (this was in September/October). Reset or deep sleep fixed it. None since .43
It is worse. e.g.Just remember, it could always be worse.....
I mean, I did have 1 headlight mostly working, so I guess you are right.
I interpreted the RJ’s comments a bit differently—essentially, it sounded like an admission that the Gen1 approach wasn’t viable, indeed it's fundamentally flawed. Specifically, relying on Mobileye’s output created latency issues that made it unsuitable as the foundation for an advanced ADAS stack. With Gen2, Rivian is pivoting to a fundamentally different strategy: adopting NVIDIA’s platform (DriveOS) and the DriveWorks SDK. By doing so, they can leverage NVIDIA’s building blocks but still develop their own business logic on top of it, rather than offloading everything to a black-box solution. Using Mobileye outputs within the NVIDIA ecosystem wouldn’t just perpetuate latency problems; I think building a software stack ontop of DriveOS/Driveworks is a large component of the value prop for the Rivian/VW JV - and mobileye integration/fusion would undermine this.They absolutely use a MobilEye system, but only the outputs if their Gen 1 methodology is any indicator. Some background:
The bad news: If you stand in front of that section, you go sterile.Well well well...
(From the 2024.51 release notes)
That’s probably a poor heat conductor so there’s only so much they can do. At least it should melt while parked.Welp... The most recent update activated the heated radar on Gen 2. Last night I had the chance to try it out! And it does indeed heat the radar and melt away snow!
But..... I still got the warning message eventually that said that the sensors were blocked. It did go a lot longer than it would have previously before I got the message, but it still did come up eventually So... Task failed successfully?
If I were programming it, I'd activate it based on the windshield sensor+outside temperature, outside of determining that the sensors are blocked.Had another chance to test the radar heater this morning, and I think I figured it out.
It doesn't seem to proactively heat to prevent blockage. Rather it seems to be triggered by the "sensors blocked" warning. About 5 minutes after I got that warning it went away again, and I got out to find a VERY clear outline of where the radar heater is. I wish they took a more proactive approach to prevent it from getting blocked in the first place, but hey, I'm glad it works at all!
