Standard pack R1T DCFC curve
KRG
Dallas - SoCal
2024 R1T
Tech Bro
Very interesting!
Glstr
Greg
PNW
Tesla M3P, Audi Q7 TDI
So, if the standard packs were really just large packs that were software limited, it wouldn't only just impact the charging curve, as noted, but it would also feasibly allow you to charge to 100% without concern of impact on the life of the battery, correct? The standard pack is just under 81% of the large pack. BTW, I'm not suggesting this as a daily thing nor would it be necessary...but for those that are concerned about charging to 100% even for the longer trips, this would help alleviate that concern, no?
jjswan33
Joshua
Sandy, OR
Absolutely. In fact I'd have no trouble charging to 100% daily if I had a commute.
Kitsap, WA
I think @jjswan33 or another mentioned before, but it's unknown where in the pack the extra 23% sits. If anyone with a Standard or Standard+ is still on 2024.03 update, they could check the Service/RiDE menu. When it's fully charged. Hopefully the extra capacity is a little at the bottom and mostly at the top.
jjswan33
Joshua
Sandy, OR
I didn't say it but with the charging curve OP got, showing 100kW input at 85% wouldn't that mean most is at the top of the pack (ie 85% on the standard pack is 70% of the large pack). Maybe my logic is wrong but if they had done the opposite wouldn't the charging curve match the large pack more closely?
Kitsap, WA
It maths to 17.6% on top end, 70% Large is about 94kWh, if that's 85% Standard, total is 111kWh, so 17.6% of the 135kWh is left. Full 100% Standard would be like 83% of the Large, maybe, because they nerf the top 4kWh.
jjswan33
Joshua
Sandy, OR
Agree with your math. DM Standard pack is a great buy right now (IMO) at $70k (R1T), $75k (R1S).
I wouldn't be surprised if the software limited large pack is a short term phenomenon.
usofrob
Robert
Tesla 3, lotus Elise
MBSE
The SP is advertised as 106kwh. Not sure how that effects your calculations.
Kitsap, WA
Does that include the nerf? 111kW is just the top-end marker, so my guess is the bottom-end is somewhere between 7-12kWh. Even 7kWh is a really good buffer.
EvAdventure13
I don't think so, I think it's all top end buffer.
From Rivian the usable capacity of the large is 131 kWh and standard 106 kWh.
If you look at the charge curves for the large pack here:
https://www.rivianforums.com/forum/...48-recent-dc-fast-charging-l3-sessions.22635/
The large pack actually hits 100 kw charge rate around 68%
68% of 131 is 89 kWh
85% of 106 is 90 kWh
If there was bottom end buffer on the standard pack, you would expect it to hit 100 kw charge rate at a number less than 85% SOC
As far as my every day use for my standard pack, I am charging to 90% which nets me about 250 miles, if I need the full 270 miles I wouldn't hesitate to charge to 100%
