Lots of people are using trailers with LED lights without a problem. Seems like a leap to conclude that "Rivian has a build problem with trailer lights and since it is illegal to sell incandescent lights it has a problem with all new trailers".
So what could be wrong? One issue that people have had is that the 7 pin outlet on the Rivian is pretty tight, and unless you push the plug in really hard the pins might not all make a connection.
Also if you've built your own 7-to-4 adapter, I would check the pinouts carefully.
Mine works fine with LED lights. It's difficult to check that they are working by yourself though, because it turns them off quickly when you exit. Recommend hitting the hazards instead of the turn signal.
I second the suggestion to double check that you have the adapter inserted completely, if the latch doesn't come down then it for sure needs to get pushed in further. It can definitely feel like it's all the way in earlier than that.
Have used many trailers varying from new to old using 7 pin to 4 pin adapters. Have never had an issue. Have used both LED and non-LED lights.
Are you sure you're plugging it in all the way? Does the Rivian recognize that a trailer is connected? (Should pop in to trailer mode).
No problem with LED 4-pin-connected trailer lights here. Don't just assume that because you are having a problem that it is a design problem with all vehicles. It isn't that you have LED trailer lights, it's something else. Sure, there might be an individual problem with your vehicle, but it isn't a design defect.
And incandescent lights aren't illegal to sell, it's "high power household incandescent bulbs" that are currently banned. Smaller/special-purpose lights, such as vehicle bulbs, are still 100% legal and readily available at stores both brick-and-mortar and online.
Edit to note: I actually have the opposite problem. When I plug in my small cargo trailer with LED lights, the slight 12V leakage current means they're on dimly even when my truck lights are off and the vehicle is locked. It's not visible during the day, but at night if the truck+trailer are parked where it's dark, you can see a small amount of red light coming from the trailer lights. When the vehicle is on, the trailer lights are at full proper brightness.
