Update 2025.06 is out!
akc5247
AKC
NJ
2023 Subaru Ascent Touring, 2024 R1S dual motor
Have Connect+, downloaded and installed the update couple hours back.
Gen1 R1S, no issues so far
goldburger
Changed my wheels and tires to 20 dark and the wrangler at’s as I feel it’s the best approximation to my nitto recon grapplers.
the rest process was… long and loud. Lots of clinks and bangs and reset like three times.
The app graphics did not change my wheels, unfortunately.
Rade
Rade
US - Rhode Island
radmorningcoffee.blogspot.com
My R1T got updated yesterday! Will check out the features this weekend!
ajthejuice
Golden, CO
‘23 R1S,‘19 Tundra 1794,‘19 XC90
Update came through yesterday afternoon on my end as well.
On the tire/wheel swap I went with the 20” All Season and 275/60R20 stock tire option in the menu as an attempt to most closely mirror my Atomic AWZZ / Toyo Open Country AT III EV 275/60R20 setup that I just got installed.
Haven’t run them at all yet, but plan to run a GPS app to test accuracy of the speedometer on my R1S while on the road today.
zefram47
Rivian R1T, Alfa Romeo 4C
I was surprised how long it took to apply. I added a 20" AT w/aftermarket snow tires. It's really weird that it doesn't ask/specify the tire size when selecting the aftermarket option, but I'm assuming it must've still used the stock 275/65R20 size as my estimated mileage did not change. I'll have to look at GPS to verify the spedo didn't change. But really I've been getting about the same efficiency, maybe a hair higher, on the snows than the stock Pirelli AT tires anyway. I just want to track them separately now that it's an option.
treyrich2001
Orange County, CA
After the update I have the Wheels and Tires section in service, but the swap button is grayed out and non-responsive, all of the other settings under Wheels and tires are also non-responsive, I cannot press edit or reset next to any of the settings.
I was able to change the rotation reminder via the app, but no in-vehicle settings are working. I tried an infotainment reset and that had no effect either. Is there a secret to getting these buttons to work? I tried service mode, but that didn’t help either.
R1Thor
Joe
Lancaster, PA
Mechanical Engineering Lead
If you need to specify a different size , you need to specify an OEM equivalent.
Example: those of us running 275/60R20 should choose the 2025 Goodyear All Seasons, then swap to aftermarket tires and select your tire choice (you can spec all-terrain, snow, all-season, etc).
We'll likely never get a super accurate range estimate (in fact, mine went very pessimistic, reducing my 100% by around 10%), but the real benefit is having a slightly more accurate speedometer (with the Rivian -1mph default offset).
R1Thor
Joe
Lancaster, PA
Is your truck unplugged?
A few others had theirs greyed out. Remove wall charger and you should be good to go.
If it's still unavailable, try a reset first.
windblowlc
Loc
WV
Just got mine installed this morning, a gen 2 C+
Gandy14
Victoria BC
Tesla M3, R1T DM
Journeyman Carpenter
There are still issues with Rivians downloading the update. As in you are flagged for it but your vehicle has trouble downloading it.
time to update your vehicle list under your profile?
FooF
FooF
Mountain View CA
foof.me
2022 R1S Launch Green
DJ
Unplug your charging cable.
elektrode
Bran
NC
Honda Ridgeline to R1T
yeah that reset process was involved.
FYI, that wheel/tire reset also reverted my proximity lock settings. So just be aware that it’s going to reset some other stuff.
goldburger
Rivian R1T R1S Update 2025.06 is out! IMG_5879
this constant reminder will either help me or annoy me lol. Might be time to rotate these suckers lol.
Gandy14
Victoria BC
Tesla M3, R1T DM
Does this update fix the thunk/jolt felt on dual motors when the rear motor is engaged?
I hope so! I don't hear it often but once in a while since a recent update in the last few months
