Update 2025.06 is out!
usulio
Anyone else, not connected to Wifi, not getting this update yet? Gen 1 R1S.
This is one I actually want since my current tires are a different size than the vehicle thinks they are.
usulio
Never mind, just got it this afternoon
Southern R1S
2023 R1S (LE/GW/OC/20"AT), Lexus GX 460 Luxury
Builder
On my Gen1 I noticed that this update brings back the radiator grill shutters opening (and creaking) on wake. Is anyone else seeing this behavior again?
Yep. I updated last night and noticed it right away.
Wow, that's super disappointing. Held off on the prior OTA (2024.51) and was about to install this one last night but saw your post and decided to hold off for another round until the next OTA now to see if that fixes the reintroduction of that issue.
Really appreciate you both taking the time to post / confirm this bug though as I would have been disappointed with that if I updated (mostly because the 2024.47.01 I'm running currently has been virtually flawless / the most stable OTA I've had in my ~2 years of ownership).
Eh. Minor issues. The shutter creak is just plastic on plastic friction. Nothing broken. Squirt it with dry lube if it’s that big of a bother.
R1Thor
Joe
Lancaster, PA
Mechanical Engineering Lead
To be clear, there are no performative downsides to the shutters opening/closing.
In fact, Rivian may have re-enabled it for a reason.
It just (appears to) annoy some people.. . that their vehicle makes noise...
moondoggy
SWFL
Range Rover, Mini
Anybody else:
Mirror Tilt not working correctly? They tilt down on reverse, but don't go back to normal once in drive/driving. Reset doesn't fix. Super safe.
Sirius XM won't actually pause either... park, press pause, come back to car hours or days later, Sirius starts playing on its own. Literally no way to make it stop other than backing out of the app.
Does Rivian beta test or is it us?
southerncadesi
JD
2025 Rivian R1S (Rosalina), Nissan 350Z
Any other Gen 2 owners still waiting for this update like me? I feel like this update has been the longest wait since initial release.
Contact Support and request to have it pushed. It was probably already pushed to you and you missed it somehow (connectivity interruptions), since rivianroamer shows 100% deployment.
southerncadesi
JD
Will try this, thank you!
Rivian Roamer
rivianroamer.com
2024 R1S Quad Large, 2025 R1T Tri Max
Adventurer
southerncadesi
JD
They said it’s rolling out in phases and to make sure I’m connected to WiFi 😑
Do that and check from your center display to see if it's already been pushed but stuck while downloading (vehicle settings > vehicle > updates). OTA download in the background when parked. You driving it, or connectivity interruptions, will cause download to pause. And you do not get notification (or awareness of update being available to install) until download is complete. If you want to be less in the dark, use a secondary email of yours, invite "yourself" as a driver, then use that email to link your account to rivianroamer. Once linked, the dashboard will provide visibility over some things.
sherold
Indiana
Audi S3, VW Atlas
Unfortunately rivianromaer is only a very very small sample size of data so (for now), it is not really the best metric to use for fleet software update rollouts.
Rivian Roamer
rivianroamer.com
Adventurer
Small but mighty!
At about 1,100 vehicles tracked right now so yeah about 1% or so. Hopefully that grows over time. :)
tk21
Military
Same…also rear screen clock is stuck displaying the time at which it wakes…
