Wet spot under driver mat
Electrified Outdoors
Mount Airy, Maryland
EVoutdoors.org
Real Estate
Hold up, so it’s been with them since January and it’s now May? Where are you located?
February 9th. I promise I will update you all soon. I don't want to share anything more publicly until the issue is fully resolved.
Iatros786
Floriduh
74 Vette, 997TT, Q7
Yeaaa.. so just put in a ticket as well for water under drivers mat. Had some white discoloration there as well.
Anyone else get theirs permanently fixed yet?
Earliest service date is a long ways away for water to be sitting there. Heading home to hit it with the Bissell
Rivian R1T R1S Wet spot under driver mat 20240514_133425
jerseyff
jerseyff
Darren
McDonald, TN
R1T; Model 3 Highland
My HVAC(?) system was replaced Sept 2022, 4 months after my delivery. I have not had water under the mats since. The vehicle is not garaged.
tuxrider
Shiv
Milpitas
Noticed same issue on driver side today. Submitted ticket,hope nothing serious. Took delivery August 23
EVoutdoors.org
Real Estate
Tell Rivian you need to bring it in right away and that there is water in the vehicle. Once mold/mildew start to grow it will be very difficult to get it out.
Iatros786
Floriduh
74 Vette, 997TT, Q7
100%
Earliest available is in 11 days... I'm afraid the damage is probably already done. I was able to extract approximately 75 to 100 ml of fluid
jerseyff
jerseyff
Darren
McDonald, TN
When mine was waiting to be repaired, I found a tiny fan, plugged it in and rested it on the sunglasses cubby on the driver seat and left outlets turned on so there was airflow.
Ilovejunebugs
Emily
Wisconsin
2026 R1T Quad Max
business owner, retired RN
I noticed this issue for the first time yesterday, after driving for 3+ hours in the 95 degree heat with my AC running. I have an appointment to bring it to the service center in two weeks. I'm the second owner but the truck was originally delivered May 2022, Vin xx4xxx.
jerseyff
jerseyff
Darren
McDonald, TN
Same timing as my truck, May 2022 delivery with a 4XXX VIN.
jerseyff
jerseyff
Darren
McDonald, TN
After the service center fixed it have you had an issue again?
I have had no issue since the repair, they replaced the entire HVAC/climate control system after tearing down my dash to get to it.
Ilovejunebugs
Emily
Wisconsin
2026 R1T Quad Max
Wow that is quite a repair- I'm glad that fixed it for you! I'll see what the SC says when I bring mine in. Thank you :)
Reactions: Rad
jerseyff
jerseyff
Darren
McDonald, TN
There was a bad batch of units it sounds like around our manufacturing time, some had a condensation drain issue...in c
Keep this thread updated with how yours ends up! Mine was only along as it was because they shipped the part incorrectly from the factory, took extra freight days.
EVoutdoors.org
Real Estate
Yes, design flaw in original units. Crack in HAVC assembly forms allowing water to drain into the floorboard instead of out the condensate drain as designed. I was told Rivian has a revised part number.
Unfortunately my wife's June 2023 build R1S had this issue. Rivian ultimately wound up replacing it to to delays in getting it repaired mold/mildew issue developed.
I made a video documenting what she went through. Ultimately Rivian made the situation right and kept my wife in an R1S the entire time (Half in a rental and half in a service center loaner). Went in February 9th and we finally resolved this on May 20th. My advice is if you discover water in the floorboard have it addressed immediately by Rivian.
