What technique do you use to charge 2 EVs
sinfonik
P
White 2023 Tesla MYLR, Glacier White 2023 R1T Dual Max
One 14-50 outlet on a devoted circuit and a mobile charger can reach both our Tesla and Rivian for "charge swapping" and higher mileage refills. But we typically use an additional mobile charger on a 5-20 outlet to trickle charge the Tesla.
Martyr
Martin
Olympia, Wa
Tesla model S Rivian R1T
My wife and I are going to start with the R2, but it is very likely we might add the Subaru Trailseeker also.
What strategy/technique do you use when you have to manage charging 2 electric vehicles.
Do you have one of those smart splitter boxes, just use one charger and swap cables manually, other?
I was hoping to get some good ideas from those of you who have tackled this before.
Thanks in advance....
Because our electrical panel is maxed out we opted for one NEMA outlet and a Lectron splitter and can plug our two EVs in at same time. The splitter charges each vehicle sequentially-when one is fully charged the device switches to next vehicle. We are happy with performance.
RickRivian
SE MI
'22 Lightning ER Lariat,'22 Mach-E Premium 4X
Keep in mind that for those that say they rotate vehicles every few days, that negates the advantage of being plugged in during the dead of winter to a) keep the battery warm on very cold nights and b) prep the battery and vehicle on house current.
Also keep in mind that some people got / get their chargers with utility discounts / rebates. We got our first one in 2021, and got $500 back. Got our second in 2023, and got $500 back. Now, $500 back is income-based, and we wouldn't qualify.
Lastly, keep in mind CONVENIENCE. Lots of people don't get a home charger, and find that sitting at a public charger is a PITA. Some get a home charger, and say they'll rotate cars, and then find moving cars around is a PITA. Go with the max your electric box can handle.
mkg3
R1S, Model 3, Outback, Artura
Have one charger that we use for the Model 3 and R1S. We alternate which vehicle gets charged. Since we charge overnight, one night, one vehicle, another night the other vehicle, unless we need to charge the same vehicle consecutively from driving.
Not an issue since both vehicles are well over 200 miles range. We have not had an reason for both vehicle needing to be charged at the same time for the very next day.
Feetdry
terry
Samish Island
Hydro 84
medical sales, almost retired
We have a Tesla and my R1T charging side by side in our garage with a 60 amp hardwired Rivian charger and a 60 amp hardwired Tesla charger and another 50 amp charger, that charges the Mean Green zero turn...
DD4ST
Daniel
Florida
I have one Wallbox charger on a 14-50 outlet in the garage and both a Rivian and Audi eTron. Run it a little less than max at 32 amps. Because the Audi has L2 charging ports on both sides, I just ran the Wallbox cord to mid-garage on an old door lift rail, where it drops down for either vehicle where parked. No tripping over cables! I find having one works fine, but depends on your situation. You do have plan some in case both are getting low at the same time, and it helps if one driver has some flexibility, just in case. However, the alternative if you accidentally screw up and find one vehicle low on charge is to go to a L3 charger and pay. This would likely still be less than the cost of install of a second L2 charger. Plus a second charger needs to derate when both chargers are used unless you have a lot of power available and are willing to pay for the cost of another electrical circuit. I’d say try it with one for a while, with L3 charging as a backup. If that causes you problems then you will have a better idea if you need a second charger.
cohall
2022 R1T, 2023 R1S
We have 1 Chargepoint home charger, and the cord is long enough to reach both cars. I have it rigged overhead with a spring-loaded hoist so that either of us can just reach up and grab it to plug in our car. No worrying about coiling it back up etc. We don't drive enough to need both cars charging at once.
ceejaex
Lightnging and R1T, 99% of the time, just swap as necessary with one 50amp EVSE (old Juicebox). If you own your property you probably have a conventional wall outlet available (inside garage or outside) and could trickle charge the second vehicle for the sake of simplicity (each vehicle, dedicated plugs, always be plugged in). I do have an available 50amp outlet and a mobile EVSE I can plug in, but I never do. It's possible in the dead of winter if we were both doing more driving more than usual, I'd need to do that.
I tend to manage charging and ensure wife's Lightning is charged as it's a Pro with 240 miles rated range.
BCondrey
Barry
Richmond, VA
Added a second EVSE after I got fed up with L1 charging. My wife has her Tesla Gen3 WC and I have a Grizzl-e. No more moving cars around. I am careful to not charge both at the same time in the summer (with HVAC running). My R1T is on a 9PM - 8AM schedule, wife charges earlier than that.
Thebandit
Subaru Crosstrek, Ascent
We will probably be a 2 EV household in a few years when it's time to replace our Ascent. I have an Emporia Pro for my upcoming R2. Emporia allows you to put a second Emporia EVSE on the same circuit, and they can share the specified amount of current. So I'll probably do that. I'll just put a junction box in the middle of the existing conduit run and split off conductors for the other charger.
hammick
Montana
We have two chargers in the garage. An Autel hard wired to charge at 48 amps and a Wolfbox hard wired to charge at 24 amps (I converted the travel trailer 120v 30a circuit to 240v). I could easily upgrade the wiring on the Wolfbox to get 48a out of it but we get by just fine with 24a on that one.
Before we list the house in the next couple years I'll remove both chargers and wiring as I didn't pull a permit and did the work myself.
ndmiller
Noah
Atlanta
23 R1T Silver (The AG)
Retailler
I've never kept either R1T or Y plugged in during the winter and each morning they are set to warm up unplugged for respective driver at the right time. 251miles on the R1T @ 70% and 249miles on the Y at 80%. Don't have to charge but once a week on T and every 2 on Y.
Unless you're a high mileage driver daily in both EV's this is a non issue. If you are get 2 chargers, simple as that.
forestwalker
Forest
Battle Ground, WA
2023 R1S
Ops Manager - Diesel Repair
Never encountered this issue, but I would just stagger the days you plug in overnight? I only charge once or twice a week, if same for you, just do them on alternating days..?
