Wind noise has increased over time
dleepnw
Rivian, Toyota, Lexus
I think in general it’s a noisy vehicle with regards to wind above 70 mph. However, recently I noticed the wind in the small triangle at the front of the drivers side door has a noticeable whistle. Has anyone else seen this occur over time?
i know this is a known issue. for me it hasnt been there before and now it is and hasnt seen anyone post about that before.
andrew
I think in general it’s a noisy vehicle with regards to wind above 70 mph. However, recently I noticed the wind in the small triangle at the front of the drivers side door has a noticeable whistle. Has anyone else seen this occur over time? It wasn’t there before.
Mine has also gotten worse. After two years, I now have wind noise in the passenger triangle window and on the roofline where the sunroof starts. Plus I now have a dash rattle in the speaker, a rear door that rattles, and creaky gear tunnel doors. Hoping to get service for all of these items s00n.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
The triangle window noise is a known problem, and has been discussed here and in other places a lot of times. I didn't save any links. I researched wind noise at one point and found it mentioned, plus there is a TSB on replacing a part up there. And there's a test regarding pulling on some piece which may be loose.
I did this, to reduce the noise all around the whole door, but it was not BAD on mine. I'm just a princess and want it ultra quiet.
Rivianready
Michael
Richmond, VA
2023 Rivian R1S Adventure Quad, Suburban LTZ
Business owner
I’ve noticed my R1S’s wind noise has gotten worse (had mine since November). There is something rolling around in the front roof over the driver and you can hear it when taking a turn. I have had a continuing problem with the rear hatch. When pushing the outside button, it may or may not open all the way. It just pops open but doesn’t automatically raise. I’ve taken it in once already and they have not fixed it. ?
Rivan
Rivan
Irvine
R1T, Lexus RX350, Toyota Tundra
Eng
are we talking when windows are rolled up correct ? I would say the noise is ok on my R1T when windows are rolled up, which I consider that being lucky, However, I can’t have my windows open at all at any speed because of the noise.
