RivianXpress
West Coast
R1T, Sprinter, KTM 250 XC-W, R1250GSA, Husky 501, 890R, KTM 350 EXC-F, IBEX 450
Retired Engineer
Ladiver
Jeff
Ca
What nut would fit in the crossbar track? I’m looking at creating a solid platform to mount a cooler or strap cases to. I saw someone mention a carriage bolt but was hoping for a t-slot nut option.
MTBer
Rivian R1T, Winnebago Revel 4x4
Prototype Vehicle Development
Thanks - looks like I'd purchase two of these (anything else needed?) for mounting on the Rivian bed rails if I go that route?
https://www.1up-usa.com/product/rack-add-on/
Seems if you buy the hitch rack one of the trays is fixed and can not be removed.
Hi,
I bought the Equip D Hitch Rack and converted the trays so they could also be used on the Rivian Cross Bars. I did a separate thread on this Forum about it. It gives you the option to have both Hitch Munt and Rail Mount with the better (IMHO) Equip D .
Here is the post I did on that:
https://www.rivianforums.com/forum/threads/1up-usa-equip-d-trays-mounted-on-r1t-bed-crossbars.8976/
Mysta
SC
Rivian635
MN
BMW X5, Acura MDX Hybrid, Honda CRV
I use a tailgate pad so I can get in and out of my garage with the bike on. Works great. There's lots of solutions.
Curious with the width/thickness of the tailgate - does a tailgate pad work fine for a couple of 29'ers? It almost looks like it would put pressure on the bike frame headtube/downtube joint with the width of the tailgate. BUt I have not seen a tailgate mounted MTB on a R1T in person yet. Curious your feedback on this...
Wefty
Robert
Chicago
R1T, 2008 Fit
I have used a rug on the back of a rental pickup as a tailgate pad and the bikes fit a lot better but I don't have any problems with 29ers on the R1T.
Lsthrz
2017 Tesla S, 2012 LR4
Geologist
I use a simple tailgate pad on the R1T to carry my heavy e-bike around. It has worked fine to date but, I was just in a very minor fender bender and the tailgate folded like a ‘cheap deck of cards’ and you can’t pop aluminum out like you can sheet metal so…. I’m more careful with putting pressure back there.
Splitime
Dave
Chicagoland
1973 Land Rover Series 3, 1990 Honda CRX, 2022 R1T Adventure
I was able to slide my tent over enough to fit a 1up on the crossbars too. I didn't tighten it down at all. Really only slid the tent over to improve access to the fridge I have in the bed.
Curious which Tepui tent that is band how the tent plus bike setup worked out.
Thanks!
Engineering, Dog Petting
Thanks!
Ruggedized Kukenam 3. Works fine with the bike, but some bikes you have to be a bit careful about pedal placement.
Splitime
Dave
Chicagoland
Thanks! That helps give a general visual and dimensions to compare with. I can see how the pedal could cause damage, especially with most modern studded shin destroyers.
Splitime
Dave
Chicagoland
I'm case I missed it and it's helpful, another bike/fit reference below. I spaced things for this bike first, I haven't tested my 2022 RM Blizzard yet, so might still get moved further back to keep the fatty tire from touching the truck (carbide studs tear things up).
2021 Ibis Ripley AF 29
Rivian R1T R1S 1up rack fitment on bed crossbars PXL_20250503_205112223.MP
Splitime
Dave
Chicagoland
2022 Medium Rocky Mountain Blizzard A20 on a 1up and factory crossbars for additional reference checks. With the kneel function, it works out really nicely. I'm just under 5'8" and having no issues loading/unloading.
Rivian R1T R1S 1up rack fitment on bed crossbars 1000004000
