Smeek
NYC
2023 R1S (Quad Motor, Granite
Just as easy to do it with app 10 minutes before leaving. I'm generally not so consistent that scheduling makes any sense
it’s a pretty simple software solution. my audi has it. you can set an individual schedule for each day. i work shifts at a hospital and my schedule is different each day. this kind of system works well. would love to see rivian implement it. pretty shocked they don’t have it and a legacy OEM like audi has had it for years.
emoore
Yeah, I should just start using it. It's funny - I love technology but I hate talking to it ?‍♂
Ha. I’m exactly the same. Even going as far as I’d rather read and article rather than watch a video of it. I’ll actually skip an article I’m interested in if it’s video only.
Me too!
rodhx
Rod
Alabama
R1T, R1S, M235i Convertible
ive been waiting on the 42 update cant afford to have my vehicle bricked , may be next week . i did figure the updates would need to be sequential i dont think you would be able to skip an update.
I've been on 42.1 since it became available, mainly for the much improved performance with the iphone 15. no issues
rso544
RS
R1S Quad
Next update details …..
https://rivian.software/2023-46/
Check out these new features, improvements, and bug fixes found in Rivian Update 2023.46
Highway Assist – Auto Reengagement After Lane Change
Highway Assist now automatically reengages after you change lanes.
  • While Highway Assist is active, use your turn signal and then change lanes.
  • When you center the vehicle in the new lane, the turn signal turns off and Highway Assist reengages automatically.
Navigation – Add Stops Along Your Route
You can now add multiple stops along your route and during trip planning for a customized navigation experience. Also, you can use the Rivian mobile app and Google Maps to send a multi-stop trip directly to your vehicle.
  • Before you go or during active navigation guidance, on the center display, choose Open to open your Trip Details with the option to Add Stop.
  • During active guidance, choose Add to add your next stop
  • There are multiple ways to edit your trip:
    • Swipe to remove a stop, or choose Delete when you are editing your trip.
    • Drag to reorder stops.
    • Choose Edit at the top of the Trip Details screen to edit your trip.
  • You can also add charging stops, which are shown as lightning bolts on the map. Select a charging location and choose Add Stop.
Mobile – Add Stops And Save Trips
Now with the Rivian mobile app 2.5.0 and later, you can plan multi-stop trips in advance, save them, and send them to your vehicle.
  • To access these features in the mobile app, go to the Explore tab.
  • Go to the map to create a trip or choose Add in the Saved Trips section.
  • Choose Save to add a trip to your saved trips.
  • You can now add stops to a trip by choosing Add stop.
    • Drag-and-drop to reorder stops.
    • You can also swipe left to remove a saved trip.
Clear Vehicle Settings
For your privacy, Clear Settings removes personal information and preferences from your vehicle. It also reverts user settings to default factory settings.
  • To access this feature on the center display, go to Settings > Service > Clear Settings.
  • To learn more about transferring vehicle ownership, scan the QR code in the Clear Settings screen.
Service Mode
Service Mode makes it easier for service technicians to perform maintenance on your vehicle. On the center display, go to Settings > Service > Service Mode.
Additional Improvements
  • Charging
    • Fixed an issue with the vehicle restarting scheduled charging after it was manually stopped.
    • Fixed an issue in which a charge session shows as completed before reaching the user-defined charge limit.
  • To avoid splashing passengers when entering or exiting the vehicle, now the front wipers temporarily pause while the vehicle is in Park and either front door is open. Wipers resume when the doors are closed.
  • Fixed a rare instance in which the Brake Region button in Drive Modes didn’t display setting options.
  • Fixed an issue in which the center display showed an incorrect screen when exiting seat calibration.
  • Fixed a rare issue in which the vehicle location in the Navigation app inaccurately jumps forward when the vehicle is slowing to a stop.
  • Fixed a rare issue in which the Mobile app incorrectly shows the doors as open and the range as zero.
  • Infotainment
    • Fixed an issue on the center display in which the phone panel didn’t disappear after ending a call.
    • Fixed an issue in which the Play button on the Media panel doesn’t respond when the queue is empty.
    • Fixed an issue in which, after restarting the software, the Radio panel is blank until you select a radio station.
    • Fixed a rare issue in which declining to sync contacts during Bluetooth pairing doesn’t dismiss the Loading contacts message.
I will not give up on my dream - laughed at openly and loudly by my wife while rolling her eyes - of driving in HIGH setting up to 75 mph. LET ME ROLL THIS THING RIVIAN. We have constitutional rights in this country!
DTown3011
I have to take back everything that I said about PaaK with this update. After updating the very first time, I used my phone, it took close to 15 seconds and I stood there like an idiot waiting for things to open. Since then my phone key has been absolutely flawless and it’s generally opening the vehicle about 2 to 3 feet earlier than it was previously. This is by far away the best it’s ever been.
Curious are you on app 2.5.0?
I’ve never had an issue with My PAAK but usually have the phone in my hand approaching the vehicle. It does seem like since installing the 2.5.0 app on my phone it does unlock a few steps earlier, did not really notice it prior to 2.5.0.
RexRemus
Chuck
Chicago, IL
2023 R1S
Rivian R1T R1S 2023.46 Software Update Details (Highway Assist / Driver+ / Navigation & More...) 1701715736566
DTown3011
Yes, I'm on app 2.5.0
RexRemus
Chuck
Chicago, IL
2023 R1S
Unfortunately, he said that in April 2023 as well. Not sure what their definition of "soon" actually is.
I think we know...
But the official Rivian response was from 5 days ago? Or am I reading that wrong?
ATL_R1S
Atlanta
'23 R1S Adventure
Off-road Rally mode will let you do just that. You just have to be extra careful as it disables all the proximity sensors, and changes the hydraulic roll-control to effectively act as a rear "sway bar" disconnect.
Smeek
NYC
I think we know...
no you are correct. but they also said that 8 months ago. sorry i wasn’t clear
Stretch
Boise, Idaho
Vivian ('23 R1S) & Sparky ('23 R1T)
Hmmm, I've updated to 2023.46, but this am when I changed lanes in Driver+ it did not resume in the next lane...
Anyone else tried it yet?
