R1Thor
Joe
Lancaster, PA
Mechanical Engineering Lead
I think the driver display is now overstating efficiency. Reset your trip computer and compare. The trip computer shows much less efficiency.
Yeah, except for the SoC was the 40% improvement....
All Rived Up
Steve
Las Vegas
R1S 2025 Dual/Large
Since the last Update, I can no longer hear the "Alexa" Voice. I can hear the start and stop tone but not the voice. I increased the Alexa volume but that only increased the tones but not the Voice. Anyone have a "fix"? TIA
HaveBlue
Adjust media volume instead
Nermal
Greg
Brevard, NC
1999 Miata, 2017 Tacoma TRD Off Road, 2018 Q5
Overall, happy with the update.
A few things I’ve noticed so far, some of which I’ve seen others experiencing on G1 - minor inconveniences
- Cleared SXM Favorites
- Day/night lock sound switched to all owl/night
- Climate Control came back as off
- options quick menu comes up when I go into Park
Having worked with inexcusably bad firmware updates in my career with organizations a “little” bigger and supposedly better resourced than Rivian, I’d say Rivian struck an OK balance between exhaustive QA and timely release. Looking forward to seeing how some of the other updates like suspension and smart signal go.
jbssfelix
J
Tesla Model 3; Rivian R1S
As most have mentioned, the ride over low speed bumps is dramatically better. Yay.
I do still think the suspension at "mid" speeds (30-50) could use some improvement. Rebound seems to be better, but compression still feels a bit stiff on Soft mode.
mkhuffman
When you start hearing her voice, you are really in trouble.
Rivian R1T R1S 2025.10 Update Now Installing 1000000438
Installed the update overnight, checked it out this morning. All good except Spotify and TuneIn won't connect. That seems to always happen to Tune In after an update, so I'll just login in again. Tune In works fine, but Spotify still won't connect. Hmmm...? So I do an Infotainment reboot, still no dice. Do a hard reboot, still Spotify can't connect?!?!?!? Never saw this before on an update.
So I wonder if it's a problem with my Spotify account (shouldn't be)? I check it on my phone and it won't connect either. Check DownDetector.com and find out that Spotify is down. 😳
DOH! What are the odds that Spotify would go down at the exact time I am validating a Rivian update? 🤬🤬
DayTripping
Timothy
DFW
FYI - Spotify is down for thousands of users. So maybe not Rivian's fault.
??? That's what I said in my post, lol.
"Check DownDetector.com and find out that Spotify is down. 😳"
emoore
I also agree that the low speed suspension seems a lot better. I just wish it wasn't as noisy all the time but I guess that's a hardware issue and can't be fixed in software.
Depends on the noise. For squeaks, ask about the jounce lines...
OC12020
Doug
Apex
Tesla Model Y, Ford F150
Good morning! I got the same error since the update. Tried the three-click and hold. (I do not have a key fob) using the tailgate button. Can hear the servo clicking but to nada. I rebooted the truck (press and hold the outer most steering wheel buttons for 15 seconds) and then repeated the 3-clicks and hold, and that cleared it! Though the cover made a lot of popping sounds as it opened and closed.
Also note: It's 3 very FAST clicks on the cover button, then a long hold.
Thanks for the info. I tried the reset about 20 times and it did not fix the cover. One cup of coffee and then I tried hitting the button as fast has possible and it worked,
mkhuffman
As you get older, your reflexes slow down. FYI.
:CWL:
