Yota2R1T
Rich
Calgary, Canada
Blue 2024 R1T, Large-DM, 21", OC int.
Solar PV professional
Rivian R1T R1S Post your commute stats - New energy monitor is great! 1000009634
Just getting used to the new in-vehicle energy app and wanted to post my thoughts.
Also, let's see your commute stats... Can you beat 2.2kWh with 1.1kWh of regen??
I think if there was a less cutesy interface I would prefer it, but I get the branding and approachable vibe.
Session details I love. Just the info I wanted to see - thank you Rivian!
Energy use is on 1 minute intervals, which is what I would expect. Feedback from some online reviews/figures had me expecting random, or ~ like 16 min intervals.
Showing coloured break-down of the use-categories is great!
Parked stats is super cool, can't wait to play around and start understanding the year-round energy use on climate control, etc.
Let me know what you think about this new feature!
Enjoy
natcc99
R1S & R2 on Reserved
Enjoy
I like it too. Like you said, it's easy to understand.
The scale of the y axis going from drive to park alarmed me the first time I saw it. I can see why they didn't make it consistent between the two; as it would have made it hard to see the parking status.
I'm glad they kept the one on the steering column too because that's really easy to view at a glance while driving.
Anyways, I appreciate Rivian doing this. It's great to know more about the vehicle.
I think Rivian already pulls data from us; so it's a nice that they give back and we see data about our cars.
narmstrong79
Nick
New Hampshire
www.youtube.com
Marketing
The energy app is a great step forward, but it's not great. I think the way they display regen is less intuitive than just having that built into a single bar, but overall I am happy they finally added this.
MrMusAddict
2023 Rivian R1T
Data Analyst
One thing I noticed about the chart on the dashboard is that they decreased how much the average rolls.
I know it shows data from the last 15 minutes, but each point on the Y-axis felt like it was taking a 5-min average. Now it feels like each point is taking a 30-second average, or something like that.
I.e., the chart is "spikier", and I approve!
zefram47
Rivian R1T, Alfa Romeo 4C
The driving energy monitor is great so far, but I'm pretty irritated what I'm seeing on the "parked" page. As with what I'm seeing in ElectraFi, my truck basically doesn't sleep while I'm at the office, so it uses a lot more energy than it should. If it does sleep, I might see around 1.5 kWh/day if it's just sitting. But I was somewhere yesterday for about 2 hours and it burned through 0.5 kWh in that time just doing nothing and it was all "systems" with maybe 0.1 kWh being Gear Guard. I started using the key fob again with proximity turned off for my phone because it would keep locking/unlocking even when I wasn't particularly close, but turning off proximity has no effect on the truck staying awake a lot of the time.
R1Thor
Joe
Lancaster, PA
Mechanical Engineering Lead
28kW net with 5.3kW regen
One way
CANCERDOC
Southern California
2024 R1S PDM
Healthcare
I know the Out of Spec guy didn't like the energy screen but he's also a blabbermouth and likes to have the compass on the nav always pointing North, which is just a weird way to look at a map for a moving vehicle (it is a perfect fine way to look at a paper map however).
I do like the "instantaneous" (ok 1-2 min intervals) of energy use - it encourages one to be lighter on the pedal and to use more regen. The icons on the right side are also easy to interpret.
I do not understand however, the 1/3rd of the screen on the left side and what the purpose is. I don't care how many miles of range I will use up in an hour. It's such an irrelevant number. miles/KwH is the only value that matters. A smiling Gary and the energy feedback is fine, but the number should be replaced with something like "miles gained or lost" due to good use or poor use of regen, just to encourage the driver. Modern hybrids like to report how many miles you "saved" or "gained" via the hybrid regen. Maybe that should be the value on the left side instead of "how many miles you will use up in an hour of driving."
mikehmb
SF Bay Area
Alright dangit - I'm ALSO one of those weirdos that keeps the map pointing north.
mkhuffman
There are multiple vampire drain threads that discuss this issue, but I have noticed the same thing. At home it sleeps almost all the time. Away from home it never seems to sleep. Why?
I recommend we move this discussion here:
https://www.rivianforums.com/forum/threads/vampire-drain-0-2-day-essentially-zero.45842/
Polar
C40, LE CY R1S
This one made me incredibly happy as look at the peak value - so I got instant Back to the Future vibes. Also, instead of kilowatts, I now refer to them as Garywatts.
I took the photo a few minutes before I got home so it didn’t change the scale on me.
Rivian R1T R1S Post your commute stats - New energy monitor is great! IMG_6203
goldburger
Sorry if this has been covered before but the Miles on the right confuses me.
It says 41.9 miles but the math for energy used is 32.3. So it *adds* regenerated miles to it? Shouldn’t it be subtracting those miles? Right now it reads as it taking me 41.9 to drive 26 miles, but if you subtract the 9.6 regenerated miles it’s 22.7 to drive 26… I’m confused…
Rivian R1T R1S Post your commute stats - New energy monitor is great! IMG_8186
blank_lemur
Todd
Folsom, CA
www.printables.com
2023 R1S Gen1 Quad
Tap the "41.9 miles" so it switches the units to kWh and don't go back :)
edit: and for clarity on what this means... it says you consumed a total of "41.9 miles" of energy (which doesn't really make much sense imo, hence using kWh), but regenerative braking gave back 9.6 miles of energy. This means you used a net of 32.3, which is broken out below: 29.1 was used to move your vehicle, 2.3 was used for AC, 0.9 for general system stuff.
goldburger
Sure but that still doesn’t explain it… why is regenerated miles added to used miles, or why is regenerated kWh added to used kWh… shouldn’t it still be sibtracted?
blank_lemur
Todd
Folsom, CA
www.printables.com
2023 R1S Gen1 Quad
Sorry, I had edited my previous post with slightly more details, but it probably also still doesn't answer this question. The graph is showing "consumed" energy, hence they could be all considered negative values (though it doesn't show that), so it shows "+9.6" to indicate you added this much energy from regen.
goldburger
Oh I see the edit… so the bottom numbers are the net, after the regen is taken out?…. But that still is an illogical way to display it. How is it distributing that 9.6 miles… I guess maybe directly onto the propulsion? So only propulsion is minus reign, but the rest are spot on? My brain hurts and I feel the net number should be the largest visible one, so much so I feel they accidentally did PLUS region instead of MINUS ¯\_(ツ)_/¯
