Mark_AZR1T
Gilbert, AZ
jackpucks.com
R1T Launch, R1S Canyon Red
This is the new jack point for the R2. The 2"×4" high‑density polymer pad is the designated load surface, and the cavity in the center is difficult to justify from a functional standpoint for service facilities. The cavity would most likely be for a Rivian supplied scissor jack? Nothing outside that small rectangle is weight‑bearing, which means no traditional floor jack or bottle jack can properly interface with it. From a serviceability perspective, it’s an unusual choice
Rivian uses a small‑diameter round aluminum puck with a cross‑hatched top for lifting, and as a vendor, I’ve seen both that puck and the service‑center lift adapter firsthand. This design has the potential to create real challenges for tire shops and general service facilities unfamiliar with the R2’s lift geometry, as well as the DIY crowd.
When speaking with the Rivian team, they noted the jack point was optimized for their service centers. Even so, the R1 design is significantly more forgiving when it comes to locating and securing a jackpuck (lift adapter). Below is an example (photo taken by me) of the cross‑hatch imprint from the production R2 lift puck provided by Rivian Engineering.
Rivian R1T R1S R2 Jack Point Design - Potential Issues / Challenges R2 Jack Point
DuoRivian
Rivian R1T and an R1S
Thanks for sharing, this is disappointing. When people go to buy new tires this is, as you mention, going to cause problems.
I really hoped for jacking and for 12V battery would be more normal than R1 to make it easier out in the real (non Rivian service center) world. Oh well.
This is the new jack point for the R2. The 2"×4" high‑density polymer pad is the designated load surface, and the cavity in the center is difficult to justify from a functional standpoint. Nothing outside that small rectangle is weight‑bearing, which means no traditional floor jack or bottle jack can properly interface with it. From a serviceability perspective, it’s an unusual choice.
Thanks for the heads up, are you guys going to create pucks for the R2?
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
We have a couple of designs already made, but there are just so many compromises with the OEM jack point, that it is literally baffling to me.
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
Mellowyellow
@Mark_AZR1T In your opinion, is there an actual reason for this? When they say the jack point is optimized for their service centers, what does that mean? It looks like its optimized because they only want them lifted by service centers.
dleepnw
Rivian, Toyota, Lexus
Guess the crossbars aren't the only thing not compatible between the R1 and R2. Looks like were going to need jack pucks unique to this design. Strange choice.
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
I would imagine the divot in the center to help with properly locating what ever jack pad they whipped up for the R2.
I get the idea, but the R2 jack point simply isn’t machined for positive engagement. There’s no defined locating feature, and the center cavity isn’t a keyed geometry (look at rounding of edges). Unlike the R1, a puck can’t lock in, everything depends on friction and precise placement.
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
Maybe there’s a rationale we haven’t heard yet, but as it stands, the R2 jack point is nowhere near as secure or intuitive as the R1. “Optimized for service centers” feels more like “only safe in service centers.”
Oldsmobile_Mike
Manassas Park, VA
FG/FE R1T recv'd 3/31/2023
I build stuff
This is the old "engineers aren't mechanics" saying all over again. They had the option to design this and other components to be completely cross-compatible with the R1. Another disappointing choice. 😢
