Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
R1T Launch, R1S Canyon Red
Probably very wishful thinking but by any chance is the polymer pad raised a bit and the surrounding recessed area is 5"x5" allowing for some shop two post lifts to fit in the cavity but only pressure lift on the 2"x4" pad?
Wishful thinking. There will need to be some interface between any lifting device (floor, commercial, etc.) for this to work.
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
Not clear in the picture but it appears that you could lift it with a standard floor jack without the use of pucks. The required use of pucks for R!’s is always a LIMFAC on who can service these, both in training and equipment.
The only load‑bearing surface is that 2" × 4" pad, and most floor jacks don’t match that footprint. Nothing I’ve seen would sit on it securely. Some scissor jacks, though, have a narrow top saddle that might mate with it natively if Rivian includes one.
Eric9610
So. Cal.
R2 LE, R1S QM, MB E350, X7
An adapter will exist that is cylindrical for the jack side and 2x4 on the car side. These were 100% made for side lifts in the SC and also on the production line..
I wonder if instead of "optimized for service center" they meant "optimized for manufacturing".
Bingo!!
So far...
12V battery located/hard to reach under rear seat.
Rear doors mechanical release requires removing a panel, locating a pull cord and yanking on it.
Jack point poor design choice for owners?
Vampire drain? Of course no reports on that yet, but that might be a deal-breaker for some of us if it's not close to zero like on many other EV's.
kurtlikevonnegut
SC/TX
2023 R1S DM, Honda Odyssey
My first thought when I saw the design was that it looks like a saddle top on almost every scissor jack I've ever used would fit into those grooves. If that's the case, it would actually be easier to lift on my own than my old Jeep was because getting that saddle aligned right was a pain.
mroe
Oakland
Incredibly questionable design decisions. I would love to hear from Rivian about these choices because I struggle believing these are the right tradeoffs even for cost reduction purposes.
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
I run flat‑top scissor jacks in both R1s for our magnetic pucks, but the R2 kills the safety net. There’s no keyed feature to lock a puck in place, so alignment has to be dead‑on every time. The R1 had a centering pin location, and shops STILL lifted them wrong. The R2’s design is basically an invitation for tire‑shop carnage.
FooF
FooF
Mountain View CA
foof.me
2022 R1S Launch Green
DJ
The R2 does not have an air suspension and is much lower to the ground than an R1. I think it should be much easier to lift than an R1. A puck with a rounded rectangular protrusion on top should keep a puck lined up but you will have to be careful holding it in place when raising the jack into position.
crashmtb
Man oh Manitoba
Have none of you ever seen a mercedes or BMW jack point?
Have you had an opportunity to see the jack that's included with the R2 spare tire kit? Will be interesting to see the contact point design...
Zathras
Carlsbad, CA
Subaru Crosstrek Plug-in Hybrid
This is the new jack point for the R2. The 2"×4" high‑density polymer pad is the designated load surface, and the cavity in the center is difficult to justify from a functional standpoint. Nothing outside that small rectangle is weight‑bearing, which means no traditional floor jack or bottle jack can properly interface with it. From a serviceability perspective, it’s an unusual choice.
Rivian uses a small‑diameter round aluminum puck with a cross‑hatched top for lifting, and as a vendor, I’ve seen both that puck and the service‑center lift adapter firsthand. This design has the potential to create real challenges for tire shops and general service facilities unfamiliar with the R2’s lift geometry, as well as the DIY crowd.
When speaking with the Rivian team, they noted the jack point was optimized for their service centers. Even so, the R1 design is significantly more forgiving when it comes to locating and securing a jackpuck (lift adapter). Below is an example (photo taken by me) of the cross‑hatch imprint from the production R2 lift puck provided by Rivian Engineering.
That's facing down, right? So the weight is being born by the cross-hatched part I would think. The divot is for registration and to keep it from slipping off, no? I'm no engineer, but I suspect the engineers at Rivian have good reasons. And it's not some puny bit of money they might get for making people by a new set of pucks for less than $200 while selling $2,000 paint jobs.
So why would we not buy compatible pucks (magnetic preferably) and carry them in the car so wherever we might take it, they have the correct part to do the lifting? Anyone not competent to handle that properly doesn't deserve my business.
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
The 2"×4" pad is the only load‑bearing surface, and it’s a slick high‑density polymer, so magnets are off the table. The cavity helps with rough location, but the rounded corners make it less than ideal. With no magnetic coupling, every puck has to be hand‑held or placed on a floor jack and guided precisely onto a very small contact patch, which I can do readily at home. The question is. Can a tire shop do this reliably?
For our business, the R1 design would have been ideal. Ultimately, we will have a product for this, but it isn't as practical (as R1) is my foundational point. I imagine people will end up with a 2.5" diameter piece of high-density rubber (Tesla style) and call it a day.
Proxy
Me
Ventura County
R1T R1S
Professional
I like the Mercedes and BMW jack points. However this looks slippery and too big in one dimension to fit most floor jacks. If it is replaceable, like some German cars, maybe someone will come up with a better design.
R1S88
Massachusetts
The mandatory annual Massachusetts state vehicle inspection requires lifting of the front end to check the suspension. It's a pain to find a shop that will use my pucks to lift the vehicle correctly, as the Rivian service centers won't do the inspection. This will make it an even more stressful annual experience.
ukyank
Pittsburgh
wienermobile
Just thinking out loud here- would it be possible the entire recessed area is jackable (is that a word), and a square rubber pad could be used with an indentation for the smaller rectangle pictured for use with normal jacks?
