SACDFJC
If you really need one I have a spare. DM me your mailing address and I'll drop it in the mail to you.If that hitch cover should happen to fall off and get lost I sure could use it
Great info! How did you get the plastic panel off that covers the latch? Is that just held in by clips that you need to gently pull and that whole piece comes off?My new R1S was delivered with a tailgate/liftgate that didn't align well when closed (seemed like it simply wasn't closed all the way). I decided to just try to fix it myself... and surprisingly it was super simple.
The main latch has a decent amount of adjustment in it, so I loosened the three bolts, slide it back a bit, tightened the bolts, and then tested the door. SO MUCH BETTER!
You can also adjust the tailgate position by moving the latches on the left and right that it latches to. I didn't want to mess around too much, just wanted to make the simply/easy adjustments. I am sure you can fix just about any misalignment with the right amount of time. The trim panels over the latches just pulls off to give you access to the bolts.
Yes... I filed a support ticket, but I figured I'd probably spend the right amount of time to get it perfect. Driver side alignment still isn't as perfect as I want it, but it is least looks like the door is closed properly. there is still something a little weird going on near the bottom of the rear window. Might mess with it a bit more when I have some more time.
Before:
After:
The bolts for adjusting the upper door:
Just clips. I used an interior trim tool to pop it off.Great info! How did you get the plastic panel off that covers the latch? Is that just held in by clips that you need to gently pull and that whole piece comes off?
Thank you! This worked! So easy, loosen the bolts, lift the lift gate (you are really just lifting it enough to slide the lift gate back on the bolts (which moves its position higher)... tighten bolts and done. 2 mins max. Now things are perfectly aligned in all directions.Correct! The way the service center did it was by supporting the door with some plastic stick from the inside of the car. Then they did a variation of overextending the Liftgate upwards (don’t know if I really liked it) and with some form of a rubber mallet and pushing the latch itself.
This is wait two months for service?Only a Rivian owner would grab a wrench from their toolbox and attempt to correct the misaligned panels on their $80k vehicle.
This is pretty minor stuff (along the lines of my fixing the 2nd row seatbelt that was installed backwards in the seat). I chose to have Rivian fix my liftgate because I wanted to make sure they were aware they have fit and finish problems that are not acceptable... but I also didn't have to wait 2+ months to get in for service (in fact, I had to delay the repair due to my own schedule). Perhaps a wasted effort as this seems to be a problem that they have still not addressed before the vehicles leave the factory. Perhaps if they addressed these issues at the factory, their service centers wouldn't be backed up for months.Only a Rivian owner would grab a wrench from their toolbox and attempt to correct the misaligned panels on their $80k vehicle.
I think that is just it... clearly the factory isn't even trying to align things and they are just leaving it to the SCs... who really don't have the time.This is pretty minor stuff (along the lines of my fixing the 2nd row seatbelt that was installed backwards in the seat). I chose to have Rivian fix my liftgate because I wanted to make sure they were aware they have fit and finish problems that are not acceptable... but I also didn't have to wait 2+ months to get in for service (in fact, I had to delay the repair due to my own schedule). Perhaps a wasted effort as this seems to be a problem that they have still not addressed before the vehicles leave the factory. Perhaps if they addressed these issues at the factory, their service centers wouldn't be backed up for months.
I would say it is likely working. Took delivery of mine today, I must say, alignment was near perfect all around. Paint looked good and interior was great. No issues that I can see at all. So, thanks to everyone that came before me...This is pretty minor stuff (along the lines of my fixing the 2nd row seatbelt that was installed backwards in the seat). I chose to have Rivian fix my liftgate because I wanted to make sure they were aware they have fit and finish problems that are not acceptable... but I also didn't have to wait 2+ months to get in for service (in fact, I had to delay the repair due to my own schedule). Perhaps a wasted effort as this seems to be a problem that they have still not addressed before the vehicles leave the factory. Perhaps if they addressed these issues at the factory, their service centers wouldn't be backed up for months.
I stopped short of trying to pry out the plastic molding not knowing where the clips are and if you have to take the interior portion with the carpet on the tailgate off first (I assume you have to do that first) and then the top plastic come off second.I am going to try this fix today too!
Thank you so much for posting this!!!
