SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
Overture PETG yellow is nearly exactly Rivian yellow if you use 4-5 walls.
Rivian R1T R1S Customizable Console Organizer (3D Print) 1733430091390-0e
Rivian R1T R1S Customizable Console Organizer (3D Print) 1733430103312-01
Kelvn
Irvine
It wouldn't be hard to make one extra deep, but I wonder about the usefulness. It would also be too tall for most printers. The base model is already about 193mm tall and sits about 125mm off the floor. One of my goals was to make it super easy to remove to get access to the very bottom, and these https://www.printables.com/model/1070662-rivian-center-console-dividers do fit under this (they're 120mm tall and what I currently use). I'm also not sure how strong these clips would hold something tall... I think you'd want a different solution.
Are you looking at storing something extra tall such that you wouldn't want 3 levels of storage?
Yea i am, I currently use Rob's dividers too, and I have things inserted in vertically so nothing is stacked (easy to see everything from above and grab) with a microfiber taking up the rest of the vertical space above everyhing.
I also have a kindle slid into the side, Maybe I can swap it where I put microfiber towel underneath along with other less used stuff. How much clearance is there between the main compartment floor and the armrest lid? is there at least 141mm so I can clear my Kindle?
blank_lemur
Todd
Folsom, CA
www.printables.com
2023 R1S Gen1 Quad
Yep! It's pretty close. It's what I used in my crossbar no-whistle photos. Still a bit too yellow, but close enough most folks don't notice. I've been meaning to try California Filament's Golden Yellow PETG too, as that one looks like it might be slightly more orange, which might make it a better match. Hard to tell from the photos I see.
Joe schmoe
Tennessee
Tesla model S
These are all PETG. Overture's Army Green on the base and California Filament's Matte Olive Green for the top bin. The black accessories are in Voxelab's Carbon Fiber PETG. I'm still trying to decide what color I want my final, final version to be...
I''ve been using a lot of the BambuLab PETG HF. It prints about as fast as PLA, with a very nice sort of matte finish. It works well for parts that live inside a car. I also use a lot of Bambu ABS GF which is also nice for these applications, but you need a well ventilated area for printing.
blank_lemur
Todd
Folsom, CA
www.printables.com
2023 R1S Gen1 Quad
It's 164mm from the floor of the base unit to the lids.
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Jeep & R1T & Silverado EV
I'm confident that a good PETG will be A-OK for inside of the center console. Without sun beating down on it directly, it won't be as likely to slightly deform in hot summer months. That said, I don't know how PETG+ CF or similar blends of it hold up. (that's why I print everything from ASA)
I can confirm - extra walls and more / better infill makes a huge difference. (4-5X) Over the last 2 months or so, I've gotten really into strength and durability testing, and I've been refining how both are used.
Also, there was one guy who REALLY gave me the business because this didn't exactly match Compass Yellow. (Overature and Polymaker yellow is basically identical)
kmusk01
Charlotte, NC
Network Engineer
So I just tried to print this up after downloading the files, and fail. When I try to slice only the small object stay, but the main "bins" disappear. I am using Bambu Studio for my slicer since its what I have with my Bambu X1 Carbon.
I tried adjusting some of the settings and can at least get it to "preview" but will never slice.
Also since all the parts are 1 file for download have to remove all the parts except for what I can get to fit on print bed. Are you able to upload the files separate?
Any tips or tricks to get this to work on Bambu Slicer? I have had my printer for about 6 months now, but this is the first encounter where I can't print anything.
Thanks,
Ken~
blank_lemur
Todd
Folsom, CA
www.printables.com
2023 R1S Gen1 Quad
That’s odd. I’ve never used BambuSlicer but I imagine they’re all mostly the same. The models are likely just hidden/disabled. You’d see them in the preview greyed out but then they won’t slice. There’s too much to fit on the bed at once so I normally just enable the one model I want to print, disable all the others, then tell it to auto arrange. And by enable/disable I mean hit the eye to make it visible or not.
kmusk01
Charlotte, NC
Network Engineer
I just figured it out. The 2 main "bins" were importing as hidden/disabled. Once I arranged objects to fix on plates I was able to click on the "bins" and say "print" which then unhide/enabled them :)
Printing now in PETG-HF as I have tons of it. Will keep ya posted how it turns out :)
Thanks,
Ken~
usofrob
Robert
Tesla 3, lotus Elise
MBSE
I like those hooks, particularly the front one. Is the file for that shared anywhere?
blank_lemur
Todd
Folsom, CA
www.printables.com
2023 R1S Gen1 Quad
