HOME CHARGER OPTIONS
tjrivian
san diego
Tesla Model X
I did answer yesterday see thread #8: “Thanks for the input and yes, you are correct, I’ve ‘fooled’ the OEM Rivian portable charger with an aftermarket connector to the 120v 20A outlet in my garage. I just have to remember to set the Rivian to draw 16A.”
Oops, sorry about that. Somehow I missed that post!
Kaiju
Hmm. Personally I'd tell you to get the circuit set up. Something that you'll get by on right now would be very easily upset if something changed, or if you had to deal with charging a second vehicle. Also if they ever get V2H working, you'd be able to take advantage of that, which I'd wager the portable charger would never be able to handle. Also being able to run your 240V panel is a godsend in that situation but I digress.
I'd also tell you to put the biggest wire possible and not to skimp on including the neutral even if it isn't used, because if you wind up needing it 10 or 15 years down the road you'd be looking at having to do it all over again. The extra cost of materials is basically bupkis to the labor.
Maybe the price isn't right but I'd also argue it's not as far off the mark as it seems. I had to spend about $1000 on just materials for my 14-50 plug setup, but then had to eat another $3000 in panel upgrades because my main breaker box couldn't physically fit the extra breaker (which was actually a code violation that someone got away with, but that became my problem). Depending on your local municipal codes, it might have to include building permit fees, a city inspector, installing a breaker box or disconnect in your garage and doing code updates to parts of your system, which is something you trip over with grandfathering rules.
Basically if you modify an old setup (like say adding a new circuit), you wind up having to make whatever changes are needed to bring the system up to current code. That can have a lot of hidden costs, so if you get details on what the $3000 is that can be helpful. But in the end, regardless of what you do in detail, I'd probably still suggest you get a better charger setup because I have a feeling that putting that kind of demand on a 120V circuit will wind up failing you at some point.
While a hardwired charger is the best solution, having a simple 14-50 plug on a 50A circuit is also probably a good middle ground if you want to use the portable charger at max rate. Or just want the simplicity of being able to swap chargers out easily. Just get a hubbell HBL9450 or a Bryant 9450FR (which is the same thing) because it's way more heavy duty than your home depot special and they're labeled these days for EV use.
MainLineRiv
MainLineRiv
Newtown Square, PA
2023 Rivian R1T, 2023 Corvette Stingray, 2019 Jaguar F-Pace, 2018 Jeep Wrangler
Investment Banker
Is the exsiting 20amp 120V line a dedicated circuit? If so, you might be able to just change the breaker from a 1-pole to a 2-pole and change the outlet from 5-20 to 6-20. That would get you a 240V 20amp circuit instead. It would charge at ~7miles/hour. The cost would be negligible. Perhaps that is good enough?
Just to close the loop, I had this done today (convert dedicated 20A 120V outlet to 250V). I set the Rivian to charge at 18A. It was a negligible cost and I’m now charging at 3.8kW and 7-8 miles an hour. Both figures 2.5x faster than before. Perfect for my needs, thanks for the recommendation.
narmstrong79
Nick
New Hampshire
www.youtube.com
Marketing
I’m contemplating installing a high-speed charger in my garage, although the roughly $3k cost to have an electricIan run a 50amp line to the garage has me thinking about not doing so. I only have a 6-mile commute to work, and get 1.7 kW (~3.5 miles/hour) out of an existing 20 amp line set to 16amp draw in the Rivian, so I’ll get 45 miles overnight. But when I occasionally drive long enough to require a 25% to 80% capacity recharge, it takes a marathon 2-day charging session. Anyway, here is my question: one electrician (I got 3 quotes) would install a 50amp 240v outlet and suggests just plugging the base Rivian home charger I have into that, and says I’ll get high speed charging. I mistakenly plugged my current charger into the 20 amp plug without lowering the Rivian amps and it pulled 34 amps before tripping the breaker, so with a 50 amp plug, I know I’d pull at least that. so Why pay extra for a Rivian or Chargepoint high speed charger?
This one is well priced, and has a hardwire or plug option.
https://amzn.to/4hlIuBe
The best one it typically this one
https://amzn.to/3PLHA5r
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
I ran with a plug-in portable EVSE for many years, zero issues, I wouldn't waste the money on a mounted unit. I got a free Rivian wall charger and installed it. It's far less reliable than the portables I used to use.
