NEW - RIVIPARTS Left Side Phone Mount
RWerksman
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Jeep & R1T & Silverado EV
jerseyff
Darren
McDonald, TN
R1T; Model 3 Highland
jerseyff
Darren
McDonald, TN
Must be a workplace web block! That's a first for anything EV related if so.
Loaded fine on my phone! Sorry for the speedbump.
KubotaTed
Overland Park, KS
R1T, F150, Bronco, 812, R8, S5, Cayenne,67 Mustang
Actuary
Thank you to everyone for this thread, as well as another thank you for publishing the STL file to be able to 3D print this at home.
I ran the wire using the OBDII adapter-to-USB to get power. The white wires of the MagSafe puck will drive my OCD batty.
Rivian R1T R1S NEW - RIVIPARTS Left Side Phone Mount IMG_0321
Rivian R1T R1S NEW - RIVIPARTS Left Side Phone Mount IMG_4062
Rivian R1T R1S NEW - RIVIPARTS Left Side Phone Mount IMG_4058
Rivian R1T R1S NEW - RIVIPARTS Left Side Phone Mount IMG_4056
Rivian R1T R1S NEW - RIVIPARTS Left Side Phone Mount IMG_4053
Not my cleanest install ever, but I didn’t want to dremel into any of the trim to make a custom fit either.
bgoldber88
Ben
Chicago, IL
2023 Rivian R1T LE, 2021 BMW X3 PHEV
I was trying to use that Scosche5 coupon and not having any luck
Rivian R1T R1S NEW - RIVIPARTS Left Side Phone Mount Screen Shot 2023-04-15 at 6.37.55 PM
rkalbiar
Ruben
The OBD power turns off?? Wow, normally they are always powered..
Lizardo
TX
Self
Tried to install, but the the part that hooks on top/sits on dash (L-shaped piece) snapped at the back
RWerksman
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Reach out to me via the contact form on the site with your order number and I'll get a replacement out to you.
Aykutcan87
Aykut
NYC
Which phone mount would you recommend for 1 inch ball?
RWerksman
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Depends if you have an arm. RAM mounts tend to attach to a ball with an arm, then have another ball on the other end with a phone mount or whatnot. Kinda like this:
Rivian R1T R1S NEW - RIVIPARTS Left Side Phone Mount 01-29-23_01_28_RAM-B-166-UN7U_1_1440x
If that's the case, I'd go with the PRO mount. If not, the left one.
Aykutcan87
Aykut
NYC
I ordered this one for left and right side but would like to have charging pad. I am guessing that is only available for 17mm. Is that right?
RWerksman
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
I have not seen a charging option for 1 IN. I've only seen it for 17MM and 20MM. They might exist, but I have not bumped into it.
