Noahnamo
Noah
Minnesota
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
Ok thanks do you sell or know where I should buy the actual adapter to go from the 12v to the USB?
Two different options are included with the power kit to connect it to the 12V in the truck. One is soldered (but more robust) and the other is screw together (easier, but slightly more finicky to get setup)
Rivian R1T R1S NEW - RIVIPARTS Ultimate MagSafe Charging Pad Kit 20230213_200353
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
Hi everyone - just a quick update on this:
Rivian R1T R1S NEW - RIVIPARTS Ultimate MagSafe Charging Pad Kit 20231208_120503
Today I'm launching a white version of this to coordinate with the Ocean Coast interior should you want to go down that road. It's available in limited quantities as of today for the same $35 price. ($99 for the combo with pads and wiring)
https://opensourceev.com/products/ultimate-magsafe-charging-pad-kit?variant=44306928533661
Speaking of the pads, the JSAUX white on silver pads are now available too. They are $19.99 each.
https://opensourceev.com/products/jsaux-magnetic-wireless-charger?variant=44306841501853
There is also standard free domestic shipping over $50. Shipping to Canda for orders over $50 is $9.99 flat rate.
MichaelD
LA
Sprinter 4x4 camper van (170)
Oh snap! I have to try that :) order incoming….
Any word from JSAUX on Qi2 pads, @RWerksman
ReyvaRivian
Rdad
Midwest
Pending R1S
I took inspiration from some of the other versions (likely yours as well) and created a single charging puck and key/wallet tray mod.
I wonder if there are others like me who simply need one charging pad - mostly due to second USB port in console is dedicated to camera storage. Also passengers prefer the ability to use phone while charging and use direct cable through back of headrest USB C port.
Sharing in case if there’s demand your floating version would be perfect with even more storage options.
Rivian R1T R1S NEW - RIVIPARTS Ultimate MagSafe Charging Pad Kit PXL_20231224_221716623_Original
Rivian R1T R1S NEW - RIVIPARTS Ultimate MagSafe Charging Pad Kit original_ae4e3312-8ba6-4a56-b953-7ff98d570c3c_PXL_20231224_221555464_Original
Rivian R1T R1S NEW - RIVIPARTS Ultimate MagSafe Charging Pad Kit PXL_20231224_221529741_Original
Rivian R1T R1S NEW - RIVIPARTS Ultimate MagSafe Charging Pad Kit PXL_20231224_221916525_Original
Rivian R1T R1S NEW - RIVIPARTS Ultimate MagSafe Charging Pad Kit PXL_20231224_222438079_Original
MD
i'm looking to modify this with a usb-c jack. the magsafe chargers don't charge fast enough on my phone (android with magsafe case). i think getting a usb-a male to usb-c female cable. would that work with that buck convertor? for the times i need quick charge, i can use the cable. thoughts?
Rivian R1T R1S NEW - RIVIPARTS Ultimate MagSafe Charging Pad Kit Screenshot 2024-02-17 201900
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
Maybe. USB-C is a bit weird. There is some variability in the content of the cables and the items that would potentially plug into it. The buck converter is pretty robust though, so I'd say it's a definite shmaybe.
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
Just a quick question, is the usb hub linked on page 1 still what you are using? 12V to Dual USB A Quick charge 3.0 Adapter
Can this do 18 watts out of both ports at the same time?
That is the old part that we used, up until Q3 23. We now buy an updated model more direct, but this item will still work.
It's theoretically rated up to 30W per port should whatever plugged into it support the correct QC 3.0 power output. Realistically, I've only seen up to 15W per port, which is the max for the charging pads that I've tested. If I recall correctly, these are somewhat basic regarding the combinations of voltage and amperage that it can do, so YMMV.
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
It's also worth noting that we're soft-launched an updated plug-and-go USB power kit. It's a direct wire to wire setup that is solder free and does away from the slightly finnicky screw together design. It uses the updated Molex W2W corrector and genuine automotive Tyco GET connectors, and it's the same $35 price
https://opensourceev.com/products/ultimate-charging-power-kit-v2
Rivian R1T R1S NEW - RIVIPARTS Ultimate MagSafe Charging Pad Kit IMG_2145
This will be 'officially' announced in the newsletter next week or the week after with V2 of the Ultimate Magsafe Charging Pad.
