Phone as key issues
CodemanCMC
Cody
San Diego
2023 R1T Quad Adventure, 2016 Tesla MS FSD
Just took delivery of my Adventure Quad R1T and had all the same issues at delivery with delivery rep and even had the head of the service center try to pair two separate iPhone 12 Pro phones (iOS 16.5.1) to no avail. Pushed two updates to the car with full resets, delete key, log out, delete app, restart phone, reinstall app, log-in, add key, etc and never had a successful PAAK pairing. So far 1 hour at delivery with head service tech, 1 hour on phone with digital service team, and vehicle has been at SC for 6 hours and granted them access as a driver so they can troubleshoot with a known phone that works on other vehicles. SC says diagnostic passed so they're confused about it too.
Rivian needs to update the app so it's still usable even without the PAAK functioning (like Tesla's app can set charging, lock/unlock, vent windows, set climate control, turn on/off security features, etc even on non PAAK cars like my early MS).
Will update when I have a final resolution.
Tim-in-CA
So Cal
Gen 1 R1S, Lucid Air, T-Bird
I'm actually having a weird issue with my iPad! I have my iPhone set up with PAAK, but I'll use my iPad if I want to check the status of charging. However, when I open the app on the iPad it is FORCING me to set up PAAK. I don't want to add a key for the iPad. This prevents me from seeing the current charging session as the Green bar that's on the iPhone app (View charging session) is not displayed! Has anyone else seen this?
GSGun
G
Eugene, Oregon
2023 R1S Quad, 2019 Prius Prime PHEV
I have a similar issue when I took delivery 3 weeks ago. Tried on 3 different phones (Pixel 7 Pro, iPhone 14, and iPhone 7S), tried different BT profiles, multiple resets. I have a mobile service appointment on friday and on the invoice it says communications module, vehicle firmware upgrade. I don't have any other connectivity issues at the moment. Garage opener is janky, but I'm not sure what controls that.
My name was misspelled and they changed it prior to delivery. I wonder if it's something to do assigned token from factory.
jimmyb2
IN
Chevy Express AWD, Lexus RX450h, Rivian R1S
My iPhone 13 Pro was easily paired at delivery, and as soon as I got home I turned off the phone feature that locks/unlocks the vehicle. I really dislike having my phone do that because it is so "uncertain". If the phone does that by itself then I don't really know if the vehicle is locked or unlocked when I walk into a store for example. I just do not trust it to always do what I think it "should" do.
I much prefer to press a button or turn a key or some similar physical thing. That way I KNOW whether it is locked or unlocked as I walk away. And I KNOW it did not unlock as I walked partway back to look at some other nearby vehicle or to talk to someone nearby.
I still use my Rivian phone app to do other things ... start/stop charging, change charging limits, turn on/off interior air conditioning, turn on/off security cam, etc. I just don't want my phone locking/unlocking without my knowledge just because I happen to be in the vicinity. But that's just me.
CodemanCMC
Cody
San Diego
Brief Update: SC advised they identified the issue as related to a bad driver’s side Bluetooth module or possibly a bad fuse for that module. They stated they’ve not had this particular component issue before but that the part is on order and should resolve the problem tomorrow. Generally I’m nervous this could be a larger electrical system issue as I have had very similar component failing issues in my previous ICE vehicle that was ultimately deemed a lemon after the fourth or fifth component failed (probably related to a bad wire harness or it’s subsequent replacement) so I’m probably overly sensitive to stuff like this. Hoping this is all we have because even though I’m only 6 days since delivery I love the truck!
Will post another update if/when it’s resolved.
MIG
Chicago
Prius; R1S
I can understand personal preference but it locks reliably when i'm about 10-12 feet away. Consistently get a "chirp" confirming that it's locked and I'm never concerned about it being secure. Then, just as reliably, it unlocks as I approach. I find it to be a great feature.
ads75
Reading, Pennsylvania
Utilities
It is a great feature, away from home. But for me, the truck will unlock in my driveway when I go into my kitchen. No audio chirp that it unlocked, not that I would hear it, if I am inside. And I can't see one side of my truck from my windows, no idea if someone is opening that side or not. Only clue I had it was unlocking was because I would see the handles in the open position from my window.
MIG
Chicago
Prius; R1S
Just set your proximity locking to "Off at Home." Set your home address in navigation then go to Settings>Vehicle>Access>Proximity Locking and set to "Off at Home" if it bothers you. Mine unlocks when I exit the side door to take out the garbage, but it's not a concern for me.
CodemanCMC
Cody
San Diego
Final update: issue was resolved today by SC by replacing the driver’s side door handle assembly and it’s related fuse, and bringing the handle module’s software up to snuff. Final invoice with part numbers in attached image. PAAK pairing successful first time and vehicle recognizes my phone on approach 100% of the time so far (around 10/10 approaches). Have to say excellent service so far from Rivian.
Rivian R1T R1S Phone as key issues IMG_4999
GSGun
G
Eugene, Oregon
How long did they take to figure out and repair the issue?
CodemanCMC
Cody
San Diego
The vehicle was at the SC for about 7 hours before the diagnosis was communicated to me. Part arrived overnight and vehicle was completed same day for early afternoon pickup. So about 30 hours in total. SC provided UBER credits initially and a rental once it was clear they were going to keep the car overnight.
Cycliste
Solano County, California
Amateur aero weenie
Same for me. I’m guessing the iPad and iPhone apps are the same code. I really want an Apple Watch Rivian app with a complication that shows battery charge status.
Tim-in-CA
So Cal
Yea, I was forced to setup a key for my iPad To get the app to work
txtravwill
Travis
Marble Falls, TX
R1T, F150
IT Software Director
Rivian has had my truck for going on 3 weeks now, waiting on a stupid bluetooth module/circuitry that goes in the door handle. That makes the PAAK/NFC cards and all work/pair - ridiculous! Seems like would be a small simple part to get.
trek96
2023 Rivian R1T
Television Producer
Jumping on this thread as I am now having the same issue. But reading above, I wonder if my last service had something to do with it.
Paak has worked well since I got the truck (May). The rear pass door handle was slightly misaligned and bound on deployment. After waiting 3 months, got the truck in and they adjusted the handle. Got the truck back 2 weeks ago and a few days later tried to valet it and the card did not work. Got home and checked, both key cards would not work. Called Rivian, they diagnosed something up with the module, but fob and phone should be unaffected. They made me a mobile appointment that is still a few weeks away. Since getting the truck back my Paak has gotten worse and worse. It would fail to unlock even after standing for minutes next to the truck. Today it would not even recognize my phone to start the truck (this is new). So I did the above procedure and am stuck in the loop of not being able to pair. Reading above that a door handle and module had to be replaced. Maybe something happened when my door handle was worked on?
In the many pairing loops I was stuck in, a few times randomly on my phones Bluetooth list, “Rivian sensor” 1, 2 and 4 would show up as connected. Maybe missing sensor 3 is my rear pass door they worked on? Odd they were even showing up.
And the cherry on this sundae is that when I took my truck in, my fob (which I’ve never used) was saying low battery. They changed the battery and updated software. Today it’s saying low battery again……. Good times Rivian.
