Poll - What kind of replacement tires are you most interested in?
For replacement Tire options, what best describes your interests?
  • Total voters
    107
  • Poll closed .
ksurfier
R1SQM, Tesla
Replacement Tires are a tricky thing with the R1's, lots of opinions and different options depending on your level of comfort if you step away from the OEMs.
Here's a poll to see where the average forum member stands:
Polar
C40, LE CY R1S
Honestly - probably an “XT” variety - so not all-terrain or mud-terrain but the in-between - and 295/60r20 most likely.
**As a note LT is Light Truck - and normally has to do with load capacity not tread design AT All-Terrain.
jjswan33
Joshua
Sandy, OR
You know what they say about guys who run LT tires?
They carry a heavy load!
ksurfier
ksurfier
R1SQM, Tesla
Why not go to 35"? (295/65R20)
For 34", Nitto Ridge Grappler would be perfect, only 60#s too...average MPK likely around 1.8 or so...35" is only 63# for the Ridge Grapplers...
Another good one is the 62# Toyo Open Country RT Trail:
Rivian R1T R1S Poll - What kind of replacement tires are you most interested in? 1711569561453-4f
Glembi2
Glembi
Vienna, Virginia
Genesis GV70, Civic, & Mazda3
Patent attorney
I’m hoping more off-road options will be made available for the 21” wheels. I should have checked alternative tire options before locking in with the 21” wheels.
Chewy734
Ashu
BMW, Ford, Rivian
Won’t 35s rub in the lowest setting? I love the look of these and that size (295/65R20). But, I’m hesitant until I hear more about the ride, noise, longevity, efficiency, and potential rubbing issues.
ksurfier
ksurfier
R1SQM, Tesla
Think it's hit or miss, some do some don't depending on rims/tires...there's a thread here somewhere....
Polar
C40, LE CY R1S
35x10.5 are on the menu for sure - i’m hoping at least a year out from new tires, but I’m always looking for what’s going on. I’m not even too concerned about losing the ability to drop the lowest not a huge dealbreaker for me. Really depends on the crown design of the tire and how wide the actual tread patch/shoulder is - that can be the difference between a fitting a true 35 or a false 35 tire.
pointless
Awaiting R1T
Response choices are a bit too simplified.
I’ll be looking for highly efficient ATs (+wheels) to replace stock 21s when the time comes. The Nitto Recon Grapplers do look promising, as of today.
ksurfier
ksurfier
R1SQM, Tesla
Another way to read it is:
1) OEM
2) Non-OEM heavy duty (>50#)
3) Non-OEM SL/XL sizes (<50#)
based on your description, you would select option 1 or 2.
mkg3
Unagi, Radio Flyer and Kette Car
Most interested in high performance AS 275/50/22 tires.
R1Thor
Joe
Lancaster, PA
Mechanical Engineering Lead
Not enough options, in my opinion.
For my everyday commute-to-work over the summer (non-crappy-weather months), I want as much efficiency as possible (while not compromising wet and stopping /turning traction. I'm OK with the OEM performance and wouldn't downgrade, but wouldn't mind an upgrade. A lot to ask, but if Michelin, for example, can improve any of these metrics while at least matching the others, I'm in).
For crappy weather months and my occasional off-road adventure, I have a set of ATs that are 3PMS (Yes, I know, these are NOT as good as dedicated winters. I've made peace with that because I don't have bottomless pockets. If money were no option, I'd have 3 sets of tires). The ATs I chose, I chose because they're relatively efficient for ATs, but also reportedly capable for ATs.
ksurfier
ksurfier
R1SQM, Tesla
Agree, that's why it's 'MOST' interested in, have to pick your priority...
R1Thor
Joe
Lancaster, PA
I see what you're saying.
But to me, that'll absolutely depend on the time of the year :)
ksurfier
ksurfier
R1SQM, Tesla
What do you think of this (no reviews on Tirerack yet)?
Toyo OC R/T Trail
$ 345 ea - TOYO OPEN COUNTRY R/T TRAIL:
Size / UTQG275/60R20 (33") / 600 AB
Weight43 pounds
Load / PSI115T (2,679) / 44
Width9"
Warranty45k
Estimate MPK / Range2.3 / 290 miles
Rivian R1T R1S Poll - What kind of replacement tires are you most interested in? 1711642780863-pl
