R2 non-powered frunk is a mistake?
mclark2112
Matthew
NJ
Finance
I never used the frunk in Model Y, used it al the time in my R1S. The powered up and down made all the difference.
r2fb
NJ
Tesla Model Y, Audi Q4
You can get power frunk installed aftermarket on a Model Y for about $1k, half that if you DIY. It integrates with the screen and app, you can pop it and close it as if it were factory. Maybe something like that will be made for R2
Rizzian
NE Florida
'24 R1S Adventure Quad, '93 Honda Del Sol
Healthcare IT
If I used my Frunk more than 2-3 times a year I'd be surprised. Honestly, with my Gen 1 R1S here in Florida and not much heat shielding between the front motors, HVAC fans and the frunk interior, it seems like it's always 120 degrees in there. Too hot for groceries. I only keep my charge adaptors in there.
Additionally, given the length of the R1S and my lack of garage space, I don't have enough room to easily get around the front of the car once parked, so it's a pain to unload anything from the frunk. If I had a significantly longer garage or parked outside I'd probably use it more.
sparked
R2 Deposit
If I used my Frunk more than 2-3 times a year I'd be surprised. Honestly, with my Gen 1 R1S here in Florida and not much heat shielding between the front motors, HVAC fans and the frunk interior, it seems like it's always 120 degrees in there. Too hot for groceries. I only keep my charge adaptors in there..
That would be a bummer if R2 frunk is too hot. I thought it would be perfect for small grocery trips as my use case.
KBabione
Kevin
Lititz, PA
2023 R1S Quad (8/23)
You need to think of the frunk as being like the old school trunk on a sedan. I'm in PA and use our frunk for groceries (including ice cream) year-round, but I'm only 7-10 minutes from the store.
I keep a Blue Maestro Bluetooth Temperature Logger in my frunk at all times so, but simply going to the app on my phone, I know how hot the frunk is (or has been). For $32 it might be worth considering if you are worried about the frunk temps. I originally bought to know if I could, for example, keep cosmetics in the frunk while on a 3-hour trip in the summer (I've been blessed with four daughters).
phaduman
San Jose, CA
R1T-G2,Tesla M3&MY, Motorcycles
Techie
as others have mentioned - on our MY and M3 frunks (not powered), we don't use it at all - not worth the hassle - it requires multiple tries to close by pressing right at the center etc - discourages almost anyone to "not even try". But on the R1T, the powered frunk is used by all (kids, wife, myself) and if not daily, definitely regularly. This is purely because it is quite spacious and it is powered - just press a button and move on - no need to wait to even validate. E.g. - going to an event where wife doesn't need to carry her purse, frunk is the preferred place.
I do expect 2027 R2 will have the powered built-in for premium versions at least. There has to be some reason for 2026 R2 owners to upgrade :) (wife might approve actually!!).
sparked
R2 Deposit
That doesn't sound that bad then. Other person in Florida made it seem like there was potentially extra heat from other sources like the motors and HVAC. Might have more to do with their southern location than frunk?
DuoRivian
Rivian R1T and an R1S
They will not add powered frunk for years (if ever). If it was going to be included on these models then it would be in from the start since they have been working on this for years and it isn’t new or novel technology.
Thebandit
Subaru Crosstrek, Ascent
The trunk on a sedan was in the back, away from any hot mechanics like compressors and condensers. It was also attached to the passenger cabin and had some airflow back and forth between the seat cushions and whatnot. The frunk is basically a sealed oven next to the inverter, compressor, and condenser. It will be MUCH hotter in the summer sun than a trunk was.
KBabione
Kevin
Lititz, PA
Oh - there's definitely extra heat around the frunk. I watched my frunk temp hit 115 while at a long charge at a L3 charger when the ambient temp was in the low 50's. I'm just saying that it's not an issue for most grocery/Costco runs because they're likely to be local. Grab one of the data loggers if you're interested in knowing. It stores a lot of data and will pull it into your phone when you sync.
sparked
R2 Deposit
That makes sense. It basically doesn't get hot enough for shorter trips since none of those motors and HVAC in the frunk area run long enough.
cjones1130
Georgia
2017 Audi Q7 , 2023 Red Canyon Rivian R1T
I'm guessing you're a rare outlier who uses the frunk that often. That's a bummer for you, but I doubt 90% of owners will be in their frunk more than weekly. Rivian had to make a lot of decisions to lower the cost and complexity of the R2 so they could meet volume and price targets, and the motorized trunk and charge port were easy deletes IMO.
Huh? The frunk will most likely be utilized quite often and if not daily by most.
Nthrdedhro
MI
2024 R1T (DM L) 2024 Cybertruck (FNDTN)
The wife is 4'10" and was able to close the frunk lid at the Palo block party... although she did have to get on her toes.
Good to know. 5'1" here on a tall day. Heavy frunk usage on my R1T, was hoping R2 frunk wasn't going to be an issue but plan on ordering anyway 😀
Nadus
Missouri
2021 Tesla Model 3, R2 Reservation
FWIW, Zack's wife Cambry (from the JerryRigEverything YT channel) was able to close the R2 frunk from her wheelchair.
Rivian R1T R1S R2 non-powered frunk is a mistake? 1781114573442-uv
Perfect end for the thread/non-issue.
