Range extender for R1T in the future?
iamnid
Mercedes EQE, Rivian R1S
I imagine cooling lines would also have to be set up as well as a way to wire it in to the existing electrical. Much more complicated than dropping it in the bed and connecting a plug.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
Only if you really need to maximize the in/out rate, but not as secondary helper battery. As an example, there's a battery option for my Zero EV motorcycle, and it has no cooling. But it won't charge or discharge at the fastest rate. It's just a booster for the mail battery. It's trivial to just connect power and BMS when needed.
sherold
Indiana
Audi S3, VW Atlas
No. Concerning long range EV driving, the resources for EV charging technology and infrastructure are better spent on improving the battery tech/chemistry itself, charging tech, and reducing charging times.
I feel that additional battery packs (and weight) is a short-term grab to advertise longer range and sway buyers that are on the fence about getting into an EV but, have range anxiety. It could have potential long-term benefits if they sway "on-the-fence" ICE buyers but, that is the only advantage I see for a company to invest in a range extender system like this.
Epicloop
Ray
British Columbia
Electrical Contractor
I believe it was estimated to weigh almost 2000 lbs based on the size of it, so it would require a SC visit and a forklift or crane to install, uninstall. Not very practical. Same criticism applies to the Cybertruck version that will probably never be made either...
There is zero chance the range extender would weigh anywhere near 2000lbs(equivalent to 165kwh) as that does not even leave enough payload for the driver.
so even if it were only 800-1000 pounds (to provide possibly an extra 100kwh)
I would think 30-45kwh(360-540lbs) would be a more practical size to allow for some remaing payload.
The spare tire or gear tunnel space in the R1T seems like a good place for it.
I would think 30-45kwh(360-540lbs) woulx be a more practical size to allow for some remaing payload.
That's fine. It wasn't my math that arrived at that estimate. Let's generously say it weighs closer to 1000 lbs. Still not practical.
Epicloop
Ray
British Columbia
Well to be fair even 360-540lbs is not very practical for in/out use for vast majority of people.
ElGuano
Cali
That sounds spot-on. The CT gets 320 miles out of 123kwh, so 2.6mi/kwh. They're advertising 400mi (+) for the range extender, so we're talking about an extra 80mi. That's ~30kwh more.
In addition to preserving some payload weight, you also need to add integrated cooling and structural support, so it'll absolutely be larger in volume than just adding more cells in the main pack would look like.
Agreed. I imagine once Rivian figured out that making it light enough to manage in a home garage would not provide much range, they scrapped the idea. Maybe someday battery tech will make this possible - I love the concept of it.
emoore
Agree. This will be great once battery technology gets much better kWh/lb. Right now it’s not very practical.
zapp
SF bay area
Imho an extra battery doesn't make sense, but until battery tech gets much better, I love the idea Scout is implementing with their gas powered "harvester" range extender. They have a very high take rate of this option and while this isn't most elegant solution for EV purists, it would help Rivian to address a larger market and to retain customers when the Scouts are available..
emoore
Nearly 0% chance Rivian makes an ICE range extender. Just not their business model.
Jonger1150
Jon
Howell, MI
Nerd
The problem with the Scout is that it's not 350 miles of EV + 150 mile ICE range extender. It's 150 miles of EV + 350 miles of ICE range extender.
It's a smaller battery. You're going to have another situation where most owners don't plug it in and they'll save virtually no carbon.
zapp
SF bay area
Yes that is the downside of that system, but did Scout already disclose the battery size or the battery/range-extender ratio of the Harvester version?
Would be a quite bad if they will just do 150 miles on the battery. That would just be sth like a 60-80kwh battery and looking at the size of the BMW i3 gas range-extender, the Harvester version should still have room for a bigger battery..
zapp
SF bay area
As a customer and a shareholder, I really hope they are pragmatic and not religious about it. :)
It's pretty clear that the future is full EV, but the battery tech isn't fully there yet. If Rivian could procure the system from VW/Scout and if there is a demand for it.. why not? It's a huge benefit for towing, off-roading and long roadtrips. I don't think the R2 and R3 need it, but the R1 line should offer the gas range extender as an option.
