20" tire recommendations
goldburger
Nitto Recon Grappler A/T (46#, 9.1” wide)
My truck with 21's was a paltry 2.14 m/kWh. My truck with Recon Grapplers 275/60r20 is a hysterical 1.75 m/kWh... but they look cool and I'll probably have them on my truck for years...
ksurfier
R1S, Tesla
Fake Science Lead
You must have gotten the LT (max 80 psi) tire instead of XL (max 50 psi), if XL, should be close to the OEM 20” 2.2mi/kw…
Timdb82
Tim
California Central Coast
R1T LG/FE, Lightning Lariat ER, 2011 Tundra TRD
As a data point. I replaced my stock 20's at about 23k miles because they got way too loud. I thought I wanted AT's, and did not want to change sizes. I decided on 275 65 20 Cooper Dicoverer AT3 XLT tires (61 lbs per Discount Tire website). I typically run conserve low ride height when driving distances. Sticking below 72mph stock tires I could eek out 2.1 Mi/KWh. New tires I struggle to get to 1.9 Mi/KWh. I've recently been looking into all season options in the stock size to try and get above the stock efficiency, but this thread has crushed my hopes of that.
Supratachophobia
Ohio
S
Why? There are at least 2 options, possibly 3, that can get you to 2.4/2.5 miles per kw.
LL75
lance
Dallas
I think most or not all 275/60/20 all seasons tires would give him better than what he has at the moment
Timdb82
Tim
In the stock size? The tires that have the efficiency bennefit all look to be 275 60 20. I could be missing something though.
Zorg
SF bay area
22 R1T 25 R1S
Unless I am missing something, only Michelin makes AS in 34" and they don't seem to have better efficiency than stock AT
dga965
Portland, OR
R1T (Adventure, Red Canyon; Ocean Coast, 20AT)
Unfortunately, most of the great efficiency numbers for AS tires are for the 33" (275/60/20) tires and may not include recalibration for the smaller size (3% difference, which in my opinion is significant when you are looking at gains in the range of 10%). It seems that for al the faults of the OEM 20" AT 34" tires, that Rivian has done a decent job efficiency wise.
Condor
CJ
Cincinnati, OH
Tesla Model 3, Rivian R1S
The FALKEN ZIEX CT60 A/S 275/60/R20 comes in at 46 lbs, width of 8.7”, is 116H.
anyone tried it?
ksurfier
R1S, Tesla
Fake Science Lead
Falken is only 600 UTQG, reviews show it being poor for efficiency so not likely a good candidate…weight not great either.
OEM 20” is only tire <50#, so no way to get a more efficient tire than that unless you drop down to 33” (275/60R20).
suspect the grabber is the clear winner, based on reports from some forum members…downside is may only last ~20-25k miles, but with the low cost and best range (330-360 miles) would likely provide best overall value…need to get more data on them…
LL75
lance
Dallas
I'm having the general grabbler hts 60 to be put on the atomic wheels monday. What psi should I run this set at?
ksurfier
R1S, Tesla
Fake Science Lead
Make sure it’s the XL (116 load) max 51 psi not the SL (115 load) max 44 psi. Max PSI, you could set it at 50/51 and then adjust down based on ride quality. I believe 48 is recommended, so I would keep it closer to 50 to start out. Prob. no lower than 45…so not too many options…
Usually running a couple PSI lower than recommended has a small impact on efficiency (3-5%) but can make for a better ride. Based on 48 PSI that works out to support a total weight of >10,000 lbs. Cold 48 PSI +/- 3 is where you want to be.
ksurfier
R1S, Tesla
Fake Science Lead
Here's another way to look at it:
Easiest to just follow Rivian's recommendation of 48 psi @ 60F (see below).
Efficiency-wise, it wont make much difference (maybe 0.1mi/kwh 44 psi vs 51 psi).
Follow these inflations for Temp (Cold overnite) (If >120F may need to bleed a tiny bit out...if below freezing prob. want to bring the pressure back up to 48-49 psi):
IF OCD, you could in theory adjust the pressure to ~49-50 every couple weeks in the AM.
46 psi​
@20F; at this point adjust to ~49
47 psi​
@40F
48 psi​
@60F
49 psi​
@80F
50 psi​
@100F
51* psi​
@120F; at this point adjust to ~49
Tires are designed to have a 10% safety factor due to changes in temperature and/or pressure.
Around 43 psi the safety factor is gone (so that's a pretty good number to stay above).
* - 51 psi is the max, but going a few psi over the max, say ~53 or so shouldn't be a problem specially if short duration (wouldn't want to have them at 55 consistently for weeks/months).
Looking forward to your report and photos of the AWs with the Grabbers, how many miles did you get out of the originals?
LL75
lance
Dallas
46 psi​
47 psi​
@40F
48 psi​
@60F
49 psi​
@80F
50 psi​
@100F
51* psi​
It is the XL with 116 load rating and I am having discount tires install today. Will probably running at 48 psi like the 21". The 21" lasted 16k miles with 3/32 left. Will post pics and efficiency soon. Thanks again for the detail explanation
